Old 10-11-2003, 04:35 PM
michael's Avatar
michael michael is offline
What Potholes ???
cooling fans
Need some advice. My cooling fans are on all the time. I just installed a new upper radiator hose after the old one squirted fluid all over the engine. My radiator neck is also breaking apart seems as though its rotting. I put a 13lb. radiator cap on last week because the old one was leaking, now everything is fine but the fans could there be a short from the coolant shower?or a bad sensor if so where?
Wanted: Steering Wheel
Old 10-11-2003, 09:58 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I'd check the ECU to see if there are any trouble codes first.
Are you running the A/C? I think having the A/C running automatically kicks on the second fan
There are definitely temperature sensors that "close the loop" on the cooling fans.
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-12-2003, 04:46 PM
michael's Avatar
What Potholes ???
they start running as soon as the car is started, no A/C they just run constantly I thought it might have been an air pocket or a stuck thermostat so i changed the coolant installed a new thermostat bled the system and their still on. The cooling sysstem is working just fine pump is ok. I'll check the codes in the morning I could still use info on the sensors pics if possible. thanks
Old 10-12-2003, 05:29 PM
Hi Mike,
The fans are controlled by four relays which you will find in a separate block to the rear of the distribution and fuse assembly beside the battery. They are numbered front to rear 1 -4 with 4 close to a fuse assembly, all this presuming LH and RH drive cars have the same arrangement.
Relay 1 grounds all fans, 1& 2 control the left hand fan and 4 the RH fan.
Remove the fuses one by one and note if and when the fans stop and report back here for more assistance.
Old 10-14-2003, 06:12 PM
michael's Avatar
What Potholes ???
I pulled the fuses & relays, heres what I got.
Old 10-14-2003, 06:30 PM
michael's Avatar
What Potholes ???
sorry for the lousy pic
Old 10-14-2003, 11:33 PM
Great work Mike,
If every one with a problem came up with that sort of info life would here would be a piece of cake !
You have a short to ground. The fans are controlled all at once by opening the negative circuit to ground via relay (1) (Fan Ground) and removing this should stop all fans. It does not, as you have proven !
Somewhere, somehow, the negative wire from the fans, it can be any one as they are all connected in parallel, or the return wire to the relay assembly, is making contact with the body/chassis and as a result providing a negative return circuit without the fan relay being closed.
P.S. If not the actual wire, a connection terminal or plug may be some how shorted to ground by something which should not be there.
See what you can find and again report back. We WILL fix the bugger
Old 10-15-2003, 05:06 AM
svx_commuter's Avatar
Could one of the relays have a short to ground? (Detective Trevor )
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 10-15-2003, 05:20 PM
No.
But taking what is possible to the extreme there could be a short to ground within the relay and fuse mounting assembly. Nothing indicates such a short.
You say the fans stop when you have removed the only relay in the negative and ground circuit. All the others are in the positive circuit. I gave all of this very serious thought before suggesting what you should look for.
Old 10-16-2003, 05:50 AM
Trevor,
Is there anyway to hook a switch into one of those relays to turn the fans on manually? I am thinking about doing this to provide forced cooling when the engine is turned off on hot days.
Old 10-16-2003, 03:27 PM
Trevor,
Yes and there are several ways of doing this. Three separate control circuits are involved. Without looking at the wiring diagram I would say that a triple pole switch or a single pole switch together with a network of three diodes or a triple pole relay would be required.
The existing wiring would have to be broken into with tap on connectors close to the fuse/relay assembly or closer to the fans.
It would be a good idea to fit delay release timer to keep the fans on for a set time after the ignition is turned off.
All that said I am not convinced that this would be worthwhile as without the water pump running the only cooling circulation would be as a result of thermo siphon effect and this would quickly cease.
Old 10-16-2003, 08:01 PM
michael's Avatar
What Potholes ???
I can't seem to find any shorts, I did however stumble upon an earlier problem.
If I pull out the fuse for the A/C in the bottom right corner of the fuse box the fans stop, could this be related to my problem. I also checked the ecu for codes and got nothing. I accidently plugged the blue wire into the 1st pin on the diag. plug and got a cycle from the fan: relay clicks fans come on then off and it repeats.
P.S. they stop but do not go back on even when they are supposed to when the A/C fuse is unplugged.
Old 10-16-2003, 08:13 PM
lee lee is offline
based on your last input I think you should consider an examination of the trinary switch. It is on the right side of the radiator and since you mention a previous radiator problem it could be this switch has malfunctioned - it has a fan control function through the A/C system.
Old 10-16-2003, 10:01 PM
michael's Avatar
What Potholes ???
What if the ambient sensor is too close to my tranny cooler?
Old 10-16-2003, 10:27 PM
deadeye95
~After lurking for many months~
Mine did that for several weeks. Was pretty embarrasing at the fast food windows with the fan going all the time.
Temperature sensor was replaced under warranty. That's what they said anyway. Fan thinks the engine is overheated....
Scott
