Old 10-10-2003, 08:23 PM
AFBeefcake's Avatar
Subaru Swapper
car making a clicking type noise
It sounds like a coolling fan thats only working some of the time. I only hear the noise some time. It sounds like its coming from under the car. I mostly hear it at idle.
I checked and both fans turn freely when off and both spin
when on.
Water pump and timeing belt replaced last year 18,000 miles ago
any one got any idears?
2005 Legacy GT
My WRX's Cardomain Page
Old 10-11-2003, 06:33 PM
svx_commuter's Avatar
Is it the fuel injectors? Sometimes they will click. It is a rapid sound. Another clicking noise possibility is the flex plate. Sorry. That's at the back of the engine and connects the transmission.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 10-12-2003, 11:39 AM
AFBeefcake's Avatar
Subaru Swapper
Is there any way to check the flex plate without removing the trany?
2005 Legacy GT
Old 10-12-2003, 02:58 PM
Green1995SVX
There is a little rubber plug that comes out which allows you to inspect the flex plate.
Mike
Old 10-13-2003, 01:57 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Somtimes a slight exhaust leak will produce a clicking sound very similar to valve ticking.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 10-14-2003, 05:51 PM
AFBeefcake's Avatar
Subaru Swapper
I tried to look at the flex plate by removing the rubber plug, but I can't see center of the flex plate.
2005 Legacy GT
Old 10-15-2003, 05:18 AM
The rubber plug at the top rear right side of the engine is good for checking the cracks in the flex-plate outer edge. If the clicking sounds louder from the plug hole it could be the flex plate. I think it will almost be impossible to see the crank shaft bolts from underneath but the click may be louder. Have you seen this thread? There are good pictures of the problem and Joseph came up with a way to do the work without pulling the engine or tranmission.
