Old 11-18-2016, 05:08 PM
lsupcar lsupcar is offline
WTB abs unit
My abs unit is leaking from the bottom.
Does anyone have a good used one for sale?
Trying to evaluate my options.
Old 11-18-2016, 08:34 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Re: WTB abs unit
"Leaking from the bottom...?" not sure what you mean. I have a module that failed because of circuit board corrosion but was resusitaTED AFTER CLEANING IT UP WITH CONTACT CLEANER..whoops, hit the CAPs. Worked fine after cleaning..before was giving code 10 and ABS check light was ON. Make me an offer. Will refund if doesn't get your system working.
Craig
Old 11-19-2016, 11:39 AM
Re: WTB abs unit
On the bottom of the abs unit there are two rubber caps or plugs. Brake fluid is leaking through or around this area.
As I will be paying for labor to install, I am hesitant to get a unit that is not known to brood.
Thanks.
Old 11-22-2016, 08:03 PM
Blacky Blacky is online now
Re: WTB abs unit
I'll send the ABS unit ASAP. Thanks
