Re: Momo NonAirBag Steering wheel Install
Ok so would changing the connector plugs on the Svx to match the Sti bag be possible and just use Sti airbag and steering wheel
92 pearl SVX about to revive 92 Black 4ws (Jap spec) SVX 93 black SVX 93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear 95 bright red SVX 96 emerald pearl SVX about to revive |
Search ebay for Subaru Airbag Connector Plugs if you want to experiment. Last edited by gwynethh; 07-28-2014 at 10:14 AM. |
The STi airbag is a 2 stage charge and has 2 connectors. Don't even attempt to wire the charge to work with the SVX. What I need to check whenever I manage to get my steering wheel is if the connector on the US 02-03 steeringwheel charge is the same as the SVX. From what I remember it is similar, single yellow connector with a green lock. If this charge plugs into the SVX it will be the one to use, as I know it fits the STi steering wheel. I will also check my 2nd gen legacy steering wheels laying around to see if those charges work and fit the STi wheel, just for a wider range of options.
The charge from the jdm Sti 05 wheel I have only has one connection no two, what is the difference between jdm/adm and usdm?
