Old 08-31-2011, 02:54 PM
Re: Power Steering leak!
I would not go too far . I drove mine to the dealer about 4 miles and it was ok. Steers like a truck even worse . Is it leaking so bad that it wont even run 5 min on a full PS. defiantly the tube has a hole in it ,
Old 08-31-2011, 05:19 PM
Uncamitzi's Avatar
Uncamitzi Uncamitzi is offline
Member #447
Send a message via MSN to Uncamitzi Send a message via Yahoo to Uncamitzi Send a message via Skype™ to Uncamitzi
Originally Posted by MacGyver View Post
That's right, forgot the alternator. Which also is a problem because I left the door cracked the other night and drained the battery. Jumped it yesterday for my test, but I had to shut the car down before it charged so now it's dead again. And I can't charge it without hurting the dry ps pump even more.
Fun stuff.
No battery charger?
Mitch Hansen
"uncamitzi"
This is a Dark Ride
92 Teal SVX LS-L 128K tranny swap with 4.11's
Well.. my days of not taking you seriously have certainly come to a middle .
Old 09-04-2011, 12:31 PM
WestCoastSVX's Avatar
WestCoastSVX WestCoastSVX is offline
Was MacGyver
Well it ended up being one of the rubber return hoses above the rack at the rear of the engine on the passenger side.
Cam came over and spotted some leakage around one of the clamps and graciously removed the hose for me.
It wasn't a sure deal, but I went and got some replacement hose at the local auto parts store and clamped it on and NO LEAK!
Amazing how a hose that doesn't even have a hole in it, just worn out at the clamping point after 20 years, could drain the whole steering system in a matter of 3 minutes!
Drove several miles and everything's holding, that had to be the problem. Thanks again to Cam for coming over and giving at look with a fresh set of (more experienced) eyes!
Troy
1992 SVX LSL "Serenity" 250,000 miles!
I don't care, I'm still free, You can't take the sky from me...
Old 09-05-2011, 11:59 AM
Earthworm's Avatar
Meow!
I had to replace that hose on my project car. It puts up with a lot of heat in that location and will become hard and brittle. I wish I found this thread earlier, I may have saved you some time.
