Old 09-03-2011, 02:42 PM
James Scott James Scott is offline
The Molinator
U-Joints from Canada.. for propellor shaft
I put Euro-Drive C-Clip replacement U-joints on my Propellor shaft.. Finally all 3 seemed to work. First time I tried.. it was worse than prior.. probably got needle bearings outta wack??? Had to balance rear section (will probabaly take front section out to balance to completely remove any vibration [small now]). 95% smooth now.. .
Not easy!!!
Jim
