What runs inside this tubing?
Exactly what runs inside the small black rubber tube that connects from the right rear fender to the side of the trunk lid by the hinge?
There is no other wiring that I can see. I can't believe that the tail / brake lights, backup lights, LED strip light and the license plate lights that are in the trunk lid are all connected and run through this. My reason for asking is I want to add additional lighting inside my trunk lid and connect to the existing trunk light, which is under the parcel shelf. I don't want to add additional visible wiring. I thought about running the additional small wires through that rubber conduit if there was room. I am sure those who were parting out or had swapped trunk lids would have the answer. .
Re: What runs inside this tubing?
Well, where else are those wires going to go?
Once you take the inner panel off the trunk lid you will confirm everything.
Just looking for an easy solution to get 12V power from the trunk light into the trunklid so the light comes on when I open the trunk.
Where is the switch located that activates the trunk light? In the latch assembly in the trunklid?
Universal ground, reverse, brake, lights on. Four wires - at least in the circuit. The existing trunk light is switched to ground, so you'll need to run a pair of wires to the trunklid, as everything there is permanently grounded. Assuming you'll be using LEDs, you should be able to piggyback the new lighting from the existing trunk light without causing problems.
I will be using LEDs.
If I disconnect both "grommets" or rubber plugs where they attach to the trunklid and rear fender, would there be enough room inside the tubing to feed thin 24 gauge speaker wire to power the lights? .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 08-04-2011 at 11:01 AM. |
I'll go look.
You could either install LEDs in the recesses of the trunk as a piggyback
to the factory trunk light. There are two in the "roof" of the trunk, and there is lots of space to the sides. If you really want to have lights in the trunklid you could poke a small hole through the grommets and use a black speaker wire zip tied to the factory tube.
Yep, this is how my LED tail bar is hooked up. Except I put mine in one of those wire loom tubes. Easy enough.
