Old 08-05-2009, 03:01 AM
Brandon770's Avatar
Brandon770 Brandon770 is offline
4eat question...Need help!!!
Ok here is the deal. I have a 1997 SVX that I have pulled the transmission from and done a 5 speed swap into. Left over is the 4EAT with a bad ring and pinion gear set in the transfer case... Rest of the internals are pretty much brand new when I pulled apart the transmission and inspected it. Car shifted perfect, drove fine and gear oil is immaculately clean before the pinion gear blew. Now I also have a 1990 subaru legacy with the 4eat which was towed and burned up in the process by the dumb a$$ who I got it from. Internals are fried when I pulled tranny apart. These transmission look identical from what I can tell except for the gear ratio obviously since the 90 legacy is a 3.90 and the svx is not. (sorry can't remember final drive to the svx but on with the point) The question being can I rip all the good internals from the svx and put them in the 1990 with out running into any problems. I plan on using every thing in the extension housing in from the legacy and all the internals from the svx. Is this possible. Can I do this with out any problems? the plan is to have a good legacy. Please help because I could really use a cheap fix right now. Much help was received on my 5 speed swap from every one on her so I'm hoping this is the best place to ask since every one has been so great. Thank you and any information will help. If any more info is needed let me know. I am more than willing to take pics etc. Private messages are welcome. Thanks again guys!!!
Brandon770
Old 08-05-2009, 05:21 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: 4eat question...Need help!!!
Rather than swap the internals, swap the good legacy front diff onto the good SVX trans. Search for a write up from TomsSVX on the process.
Old 08-05-2009, 11:43 AM
+1 The SVX transmission is slightly different but actually superior to the other transmissions. It fails because its made for long slow shifts since it was made to be a cruising car.
Old 08-06-2009, 01:54 AM
Brandon770's Avatar
Thanks guys. I ended up having to rebuild the transmission for there was a couple things that needed repair in the extension housing on the svx transmission. I just pulled every things apart and cleaned it all up really good and used all the best looking parts out of the two. All I have left to do is bolt the transfer case together back on, the oil lines, the oil pan and then put it back into the legacy to give her a test drive. Looks like I may end up with quite a good transmission in the long run since I used the svx casing and internals. Your help is much appreciated. Thank you. I'll make sure to give ya guys an update if I get her in soon. Thanks again.
Old 08-06-2009, 04:44 PM
oab_au oab_au is offline
You might suspect that the C solenoid/transfer valve in the SVX box may have been not working, to cause the front diff to blow. If you are going to use it, I would give the transfer valve a good cleaning as it may have been sticking.
One Arm Bloke.
Tell it like it is!
Old 08-06-2009, 10:40 PM
Brandon770's Avatar
Thank you. Where is the C solenoid/transfer valve?
Old 08-07-2009, 01:43 AM
Sorry about that, I should have said. It is in the rear housing on the back of the box. It controls the AWD that was probably not working, on yours, to allow the front wheels to spin and shock the gears in the diff.
You can see it here;
It's in the lower right hand corner of the housing. You can see the wire that runs from the main section to the solenoid. It looks like this, in the center of the clutch plates
One Arm Bloke.
Tell it like it is!
