cigarette light trim removal
Hi!
I've searched but nothing clear. Does anyone have any clue on the possibility of removing the cigarette lighter wood trim piece without taking out the entire dash console? I've managed to unscrew the upper screw from the back but only to find that there is another screw at the lower bottom; which just seems not reachable at all unless directly from the back of the console.. anyone? much appreciated!! |
Re: cigarette light trim removal
Someone correct me if I'm wrong, but I believe you have to remove the entire "visor" assembly to remove the lighter trim. I've never been able to remove one with the visor installed.
Mike
PS: This belongs in the Tech Q&A forum. That's why we have multiple forums. Thankya!
cigarette lighter unit/trim removal
Hi!
Re: cigarette lighter trim removal
just re-posted it in the correct section. sorry about that!
BTW, where you mentioned visor removal, did you mean the dash board unit? |
Re: cigarette lighter unit/trim removal
I would like to know how to do this too. I intended to replace my lighter socket at the same time I recently replaced my stereo head unit. Figured it would be a good time to do it.
Wrong. I ran into the same situation. There seems no way to do it without removing the entire console. There certainly was no way apparent to me that the visor (stereo door?) had anything to do with it, it seems the only useful way is to disassemble to the rear - but I'm sure I could be off on that.
Jerry 2005 Baja Turbo 2008 Ford Crown Victoria Police Interceptor jnj7707@yahoo.com |
Are you trying to replace the cigarette lighter assembly? If not, why do you want to take it out?
Removing it can be done by removing only the ash tray, I have done it. http://www.subaru-svx.net/forum/show...ter#post151881 Alss do an advanced search by typing in "lighter" as the keyword and svxcess or aredubjay as the user name, There is a nut that screws onto the back of the socket, which holds the socket to in place. If the lighter is not working, you may have blown the fusible link on the back of it. I replaced it on my new socket with a solid piece of wire so I would never have to do this again. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-15-2009 at 10:37 PM. |
to remove the lighter TRIM you pretty much have to remove the center dash pice unless you have some funky screwdriver. after the radio is out it doesnt take long to get it all out frist time i did it about 15 min or so.
#1 1994 Ls ebony parts car-rip #2 1994 L laguna blue - sold #3 1992 Lsi pearl white - sold #4 1992 Lsi pearl white -Ate two engines - Rip #5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree #6 1992 Lsi custom orange parts car #7 1992 Lsi green 4.44 swap. Currently for sale #8 1992 Lsi custom pearl white. Project car... sold #9 1992 Teal 4.44 swapped... sold #10 1995 Laguna Blue. Sti 19 wheels, #11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂 |
I did manage to take the upper screw out but only to find that there is another screw at the bottom end; which I could not even find "access" to...
I need to remove the trim for real carbon fiber wrapping.. any help? thanks! |
yea then you need to take all the wood grain out spedo and part of the dash out pretty easy just look for screws if it doesn't come out easy theres a screw somewhere
