95 svx dies once warmed up
Working on a 95 svx. This has me just a little baffled..It idles great untill it gets warmed up and goes to closed loop operation..Then it dies up to 5 times. Then it runs fine after that. The mass air flow sensor is new and tests fine,and all the sensors seem to test ok .Antyone have a thought on what next.Plz help!!
Re: 95 svx dies once warmed up
Thank i'll check that out ..Think im just too close to it and over looking minor problems.
The coolant temp sensor would cause that?
It used to happen to me a lot but these days its getting better |
tryed running with out temp sensors today no differance..Test look good,but it learned a new trick today now it has a irradic ideal once it is warm and will keep running about 300-400 rpm. Anyone think cleaning the throttle body might help maybe blocked air passage? I know this is a problem with toyta..
Are you getting c/e codes on the dash?
Is a vacuum line unplugged on your throttle body? Take a look to see if all hoses are connected. How long ago was your fuel filter replaced? Same with air filter...check that too. |
All of the filters and fule pump were just replaced and no there was not a c/e light till the other day when the eradic ideal startered...not that i have read all my books and looked at all the web sites and spent 2hours looking for the test connecter wires or obd2 hook up for my nemisy. do u know where the wires are or the obd2 hook up.????
All of the filters and fule pump were just replaced and no there was not a c/e light till the other day when the eradic ideal startered...now that i have read all my books and looked at all the web sites and spent 2hours looking for the test connecter wires or obd2 hook up for my nemisy. do u know where the wires are or the obd2 hook up.????Bad netsorry for the second posting
1) Use spaces properly and punctuation please; so that we can understand you better.
2) If you have a 95 SVX, it is OBD1. If you have read "all the websites and checked the books", then you'll know the black diagnostic connector is located behind the driver side kick panel cover. Refer to SVX-iw for a complete procedure.
1991 SVX L JDM |
Thank you for the tip on SVX-iw. All the books i have and sites i found, had little to no info about the SVX.
Thread Tools | |
Display Modes | |
