Old 02-26-2008, 03:51 PM
Schralper's Avatar
Schralper Schralper is offline
ARgH! Auto seatbelt
Driver's side not moving from forward position after a friend slammed the trunk closed. Moved to forward position after I got out, but no movement since.
Got the seatbelt ecu out and looked at resoldering like was suggested in other auto seat thread. But here's what my seatbelt ecu looks like inside.
Notice in closeup how the circuit board looks messed up.
Thinkin' it might be toast whaddya think?
Anyone got one for sale??
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
Old 02-26-2008, 07:23 PM
immortal_suby's Avatar
Thread Killah
it looks like toast.
but if you are handy with a soldering iron give it a try, you have nothing to lose.
Locker Link
2015 BRZ Limited 6MT
Old 02-27-2008, 05:03 AM
gsodonis's Avatar
gsodonis gsodonis is offline
I've done the soldering gun thing - it didn't work. Logic tells you that the problem is not as simple as re-soldering the joints since all of the joints look inttact (or at least they did on my board). I got ahold of another computer and the belts worked fine for a few weeks. Then one day as I got out, I heard a loud relay cycling on and off in the trunk. It was the seat belt computer. The belt had traversed to its rear most position and the relay was clicking. Had I not pulled it, it would have drained my battery. I believe that one of the microswitches that tells the computer that it has reached the end of travel is bad and the computer keeps trying to drive the motor. That generates heat, damaging the capacitors and the board.
I give up on the auto belt crap. Before I replaced the computer the first time, the belt was stuck forward - a pain while driving. This time, I removed the computer with the belt in the rear locked position and will forever more clip and unclip the belts manually. What a stupid technology in response to American's being too lazy and too stupid to buckle up in the 80's and 90's. Not too far removed from the brake/ignition interlocks that came as a result of the Audi 5000 'unintended acceleration' fiascos.
You can get a replacement computer from a junkyard for ~$10, but if there's sopmething else wrong, the computer may not last. Or you can bail and go manual - you just have to get the belt to the back first. Someone on the boards may know how to do it manually, I hadn't found a way when I tried.
Good luck.
Old 02-27-2008, 09:31 AM
nextse7en's Avatar
nextse7en nextse7en is offline
Graphic Artist
Mount you friend in the back seat. (Not the way, sickos) and give him an allen wrench to manally crank the seatbelt back when you get in the car.
Sure, you'll have to concoct some feeding/elimination system, but sweet, sweet karma will have been restored.
Patrick
1995 Ebony Pearl. S.N. 0001 "Araby"
JDM Power Mode Switch, Integrated GPS/Video Player
6Xk Miles.
1992 Teal - Sold to Mysvxrocks
[SIGPIC][/SIGPIC]
Old 02-27-2008, 11:12 AM
Schralper's Avatar
Damn I hadn't thought of this one. I might have to give it a try w/ my trunk monkey
http://youtube.com/watch?v=MkZcG_pgp0Q&feature=related
WFO!
Old 02-27-2008, 07:30 PM
Schralper's Avatar
Just noticed that the seatbelt light isn't lighting up. Soooooo, I guess I'll fix that then see what kinda trouble code I'm getting. Sheesh, one thing after another.
WFO!
Old 02-28-2008, 10:26 AM
svx_commuter's Avatar
The seat belt was acting up in my SVX and the control unit just cost to much. I disconnected the SCU. No problems any more. Best of all I am not cutting of my head when I look out the window and then open the door with my neck still hanging out!!!! The seat belts work fine. There is that centrifugal stop mechanism that works without electricity.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
