Old 09-26-2006, 07:26 AM
DarknessofDeath's Avatar
DarknessofDeath DarknessofDeath is offline
Inhabitant of Darkness
sunroof weather stripping replacement
does anybody know how to change the sunroof weatherstripping?
i mean, is it straight forward or is there a trick to it?
thanks
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 09-26-2006, 07:54 AM
thanks
The sunroof weather stripping does not keep water out...
If your sunroof is leaking, then the drains must be plugged up, there is a drain in each corner of the sunroof, check to make sure they are clear...
Old 09-26-2006, 10:50 AM
Earthworm's Avatar
Meow!
It's easy to change. I took mine off to see if that's why the sunroof wouldn't open on its own...it wasn't.
To remove just slide it down to "unclip" it.
