Old 07-02-2006, 06:27 PM
fishtail fishtail is offline
Question Transmission fluid type
Just had a tranny rebuilt. Have had the SVX 2 months, waiting for the tranny to be rebuilt. Getting it back this weekend. Looking for recommendations for transmission fluid type. Synthetic or regular Dextron Mercon 3. Any input on this would be appreciated. Thank you, Fishtail.
Old 07-02-2006, 06:47 PM
Synthetics can handle the heat better than natural oils.
I personally like BG products.
Old 07-02-2006, 06:48 PM
triumph1902's Avatar
triumph1902 triumph1902 is offline
I use RedLine D4 ATF. You can also use non synthetic as long as you change it often...and most important make sure you add a tranny oil cooler if you don't already have one.
________________________
92 Teal - Work in progress
Old 07-04-2006, 08:10 PM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
With a name like "fishtail" you really ought to attend the NW seafood meet!
http://www.subaru-svx.net/forum/showthread.php?t=31790
I use synthetic tranny fluid, but I've toasted my tranny a few times. The cooler is a must, I also appreciate having a tranny temp gauge.
Still in love with my Subie
Old 07-05-2006, 01:43 PM
seion seion is offline
Subaru Engineer Wanabe
Try Valvoline DEXRON III/MERCON, change the filter, and add a bottle of LUCAS STOP SLIP tranny additive. Should make it smooth and more reliable.
Cars I've worked on:
'05 Subaru Impreza STi, '02 Subaru Impreza WRX Wagon, '01 Toyota Celica GT, '98 Subaru Legacy GT 2.5 Sedan, '96 Isuzu Rodeo, '95 Jeep Cherokee 2WD, '94 Plymouth Sundance, '94 Subaru SVX LSi, '93 Subaru Impreza, '92 Subaru SVX LS-L, 2003 Subaru Baja.
Old 07-05-2006, 02:01 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I've heard this said about engine oil and the same probably applies to transmission fluid:
It doesn't matter too much which brand you use, provided you change the fluid often enough.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
