Old 05-14-2002, 10:55 AM
strange179 strange179 is offline
Still a member
Send a message via ICQ to strange179 Send a message via AIM to strange179 Send a message via Yahoo to strange179
Lightbulb Torque converter seperation info (bolts)
I want to share something that I have learned about the torque converter bolts and their removal/installation.
The SVX shop service manual describes removing the torque converter bolts by using a standard crescent/box end wrench. The last time I pulled an SVX transmission I endded up stripping the head on two of those pesky bolts by trying to do it that way. This time I learned from my mistake and instead removed the alternator and (carefully) inserted an 18" extension under the intake plenum. I used a 3/8" ratchet and it fit ok under there. I don't know how well a 1/2" one would fit though. The bolts were a bit stuck but I didn't even slip off once. It may have taken me a few extra minutes to remove the alternator but I know that they would have been a lot harder or even impossible to remove with the crescent/box end wrench. Last time I had to replace all four of the bolts but this time they will all be reusable. I hope this will help out anyone who does their tranny in the future. Maybe a mention of this should go into a "Tips and Tricks" if we have one.
Jay
P.S. I am on very little sleep so please forgive any spelling (etc.) errors here.
Speed Safely
Subaru, All We'll Drive
Black '92 LSl 270Kmi 5MT (W00t! for 1/4 million on 4/27/07)
Laguna Blue '94 L about 130Kmi (I think) for parts, in storage
previous: Green '92 LSl 253Kmi 5MT (sold to ron post moose adventure, sold to someone else)
previous: Maroon '92 LSl 130Kmi +- (sold to Ron, mashed by moose, crushed)
Black '89 XT6 5spd AWD (storage)
Old 05-14-2002, 12:21 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Hmm those bolts are only spec'd to be torqued to 17-20 ft-lbs so they shouldn't be too hard to get out....Unless someone previously made sure they were 'real tight'
It can be done with a box/open end wrench, even with a 1/4" driver if you have one small enough, but getting the torque on that one is not easy...
If you need any other tranny r/r help let me know...I've done it on mine.
Hope you have the front of the car high enough in the air to get the tranny out
'20 Honda Ridgeline
http://www.x35design.com
Old 05-14-2002, 01:43 PM
Still a member
tranny
I 'm actually pulling the engine. The bolts were more stuck than realy tight. I pulled the engine and trans out of the black one together. I lifted the whole assembly out. That was a really tight fit. I know it can be done with a wrench but it was so much easier with the ratchet/extension.
Thanks for the reply Steve.
Jay
Feeling slightly better. Caffine is amazing isn't it?
Speed Safely
