Old 04-29-2006, 05:00 PM
nipper nipper is offline
SVX Shopping.
I hope you all dont mind some questions.
Sometime after the summer ill be looking to buy a SVX (after my back heals from surgery), I am a long time subaru owner, and now have a Outback. IS ther any year that stands out more then others? From reading www.cars101 they all seem to be basically the same except for equipment and the option of awd vs fwd. I am fully aware of the tranny and wheel bearing issues. We think my day of driving a stick are over, as much as i would like one with the conversion. It seems like the engine is fairly robust, is this true?
What is the service interval for the timing belt, and what kind of nightmare (or dream) is it to change. Are the cars electronics aging gracefully? Does the car have any other weak points i should be aware of, or do they tend to be the usual bullet proof sooby construction. Do they have to run on premium, and about what is real world mileage (im just curious, as i dont really care, this would be a second car).
Thanks
nipper
Old 04-29-2006, 06:03 PM
intelisevil's Avatar
intelisevil intelisevil is offline
<<<Alcyone
Welcome to the Family! I see you've already made some good posts.
My driving is about 40% city, 60% hiway, I'm getting 21-24 mpg on both of my stock '92s. I've been lucky enough to not know too much about maintenance on these cars yet.
www.ecutune.com makes a reprogrammed ECU for us. There are two program modes built into it, one allows for the use of 87 octane fuel. The Ecutune module will only work on 92-95 SVXi. Ecutune has an active member (longassname) here on our forums. Go to their website to check it out.
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 04-29-2006, 08:00 PM
aww shux thanks. Thats about what im getting with my 97 OBW so at least ill be in the same range
nipper
Old 04-29-2006, 08:04 PM
BAD BAD EVIL!!!!! I just saw the supercharger ... you are going to get me in trouble
nipper
DarknessofDeath's Avatar
DarknessofDeath DarknessofDeath is offline
Inhabitant of Darkness
besides from that...i guess if you would probably look into a 94+ since they have the upgraded parts for the tranny (correct me if i'm wrong anybody)
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 04-30-2006, 06:47 AM
immortal_suby's Avatar
Thread Killah
The timing belt is a dream to change.
real world mileage on a well maintained svx should be 20-22 city, 25-27 highway.
Electronics seem to be aging fine, mostly light bulbs behind the buttons blow. Occasionally a security system mysteriously bites the dust when the battery is left dead for a long time.
Locker Link
2015 BRZ Limited 6MT
Old 04-30-2006, 07:40 AM
curly2k3's Avatar
curly2k3 curly2k3 is offline
Own'eded
Send a message via AIM to curly2k3 Send a message via MSN to curly2k3
if you drive like me...
City-10-15
Highway-20-25
98 Impreza Wago-O-Doom & Datsun Roadsters
Old 04-30-2006, 09:43 AM
Welcome to the site. You should run premium gas unless you go with the mod mentioned above. I would suggest getting a 94 or newer because of the transmission issues. The fixes were done to them and are slightly improved. I would suggest getting on a tranny filter and cooler when you get yours if there is not one on it. Good luck with the purchase.
Old 04-30-2006, 12:35 PM
PDSides PDSides is offline
Old Guy
Back surgery - been there, done that. No fun. Getting in and out of a car with a bad back can be a chore, and the SVX sits low, making it especially difficult. Once in, it is comfortable, even on long trips. As the SVX ages, we see the typical problems, seat belt malfunctions on '92-'93 models, sticking sun roof panels, electric window actuators that bite the dust, sun visors that droop, instrument lights that fail and an electrical gremlin here and there. On the other hand, the cars are probably as durable as any other their age on the road. Engines are almost bullet-proof, but gaskets get brittle and leak, the O-ring in the power steering system goes bad, catalytic converters gum up, and shocks/struts get weak. Meticulous maintenance is the key to a happy SVX. Timing belt changes every 60K miles. Transmission power flush every 30K miles. Oil & filter changes every 3K miles. Clean air filter always in place. Brake pads & rotors in good shape. If you spend a little extra doing maintenance you will spend a lot less doing repairs. Best wishes.
Preston
