Old 04-28-2006, 11:36 AM
mbtoloczko's Avatar
sans SVX
1stsubaruparts website under new ownership
Just wanted to let you all know that the 1stsubaruparts website was bought out by another dealership, and they are selling parts at list price. :-(
Auburn Subaru is the previous owner of the website, and they are still selling parts for less than anyone else that I've dealt with. Best way to reach them is by phone (866 528 5282, ask for Jason in Parts) or email (jdouglas@auburnsubaru.com).
Mychailo
Visit my locker
Old 04-28-2006, 12:04 PM
Earthworm's Avatar
Meow!
Does that mean they also sold our information along with it?
Old 04-28-2006, 12:06 PM
Jade Dragon's Avatar
Jade Dragon Jade Dragon is offline
Don't screw with the Dragon
Send a message via AIM to Jade Dragon Send a message via Yahoo to Jade Dragon
well that just sucks. I dont want to pay list, its too damn expensive. grrr
->Austin<-
1992 Pearlie (Pearl): motorsport exhaust kit (Wife's)
1994 Red FWD (Roxi): Custom X exhaust
Old 04-28-2006, 04:17 PM
mbtoloczko's Avatar
sans SVX
You don't have to pay list. Just call Jason at Auburn Subaru, and you'll get the super low prices. 866 528 5282. He's a great guy and will help find the exact part that you need.
Mychailo
Visit my locker
Old 04-28-2006, 05:05 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Well if the new guys don't have good prices, then they'll just fall prey to the Tavelocity syndrome, which means customers will just use their site to find the flight (or part) numbers and then go buy direct from the low price guys. Hope they stay around long enough to be conveniently exploited.
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 04-28-2006, 06:13 PM
I will give that a try.
Old 04-30-2006, 07:27 AM
daluvabull daluvabull is offline
FYI: subarugenuineparts.com has the same layout and prices as the old
1stsubaruparts site. I do not know if there is any connection. I did just order a 97 grille for $130
