Old 08-15-2004, 05:54 PM
mtbikerco
@!&#$ing tranny blew!!! What do i do???
Hi,
Well, long story short, i replaced the tranny fluid on saturday (not a flush, just the drain) and not 15min after I start driving it again... SLIPPING!!! and wining noises, now car will not move unless I leave it sit for a bit.
The tranny has been wining a bit lately, just a small wine (like gears spinning really fast), so I decided to change the fluids. The fluid that came out was quite brown. But Dexron 3 max life atf in. I think it started slipping because it didn't have enough fluid in it, I checked the stick before I started driving and said it was full. Well checked it again after it started @#@!ing up and it barely registered.
Put more in, then it fried. Left it over night, came back this morning, levels were high, a bit over cold F. Car was working alright for a bit then, 1mi down the road, SLIPPING!!! So after a process of stopping for a bit then going again, I made it to the bottom of the hitt i live on. Won't go up it!
What is this and what should I do?
This car has been an endless pit of money for me. OVER
Old 08-15-2004, 07:28 PM
wawazat??'s Avatar
wawazat?? wawazat?? is offline
Yeah, I'm still around
Unhappy Sorry to say....
but it sounds like the trans is toast.
Replacement or repair is your only option to keep it going.
Todd
Down to none
Old 08-15-2004, 08:29 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Re: Sorry to say....
My thoughts as well. Honestly, if you're going to repair the car, you might want to look into getting a used Legacy or Impreza trans with 4.11 or 4.44 gears. I've seen used ones for sale on Ebay for a couple hundred bucks - plus your local junkyard will have a ton of them as they're very common. Get a matching rear diff and you could have your car back on the road again for far less than a remanufactured SVX trans (~$2,500) or a completely new one (~$4,000).
Good luck!
-Chike
2006 Steel Gray WRX TR (sold)
Old 08-15-2004, 09:25 PM
mtbikerco
anyone want it?
Anyone want it?
if i fix it, I will not be able to move away, and I have to move.
I will post a new post with pictures of the body damage and throw it up for sale.
Thanx for your help.
Old 08-16-2004, 01:10 AM
If this is an obstacle in the path of your future, by all means sell it.
Old 08-16-2004, 07:39 AM
Mr. Pockets's Avatar
Moderator
You say that it'll drive a mile or so before it starts slipping? It sounds like the same problem I had with mine a couple years ago. I had it towed to a Subaru dealership who did a flush and replaced the internal screen. Apparently there was a blockage somewhere, so the pressure was dropping off very quickly until it couldn't shift or hold a gear any more. After the flush it ran perfecly...
...for about a week, whereupon it died permanently and I had to replace the tranny...
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 08-16-2004, 08:43 AM
mtbikerco
oh no, thats not a good story at all. sorry to hear that, was it because it was driven with a ****ed up line for a bit? or was it just its time?
Old 08-16-2004, 09:36 AM
Moderator
The tranny had 133k on it, so I guess you could say it was time. I mean, I don't think 133k is stellar for a tranny, but definitely above average for an SVX without a cooler on it.
I think it was probably worn substantially, and the slipping burned the clutch out for good.
There's a lesson to be learned there - slipping is bad. Sometimes they start slipping for reasons other than a worn clutch - brake band needs adjustment, blockage in he fluid passages. But if you let it slip a lot, you're going to ruin the clutch anyway.
Of course, if it's slipping because of a blocked fluid passage, the debris causing the blockage is likely clutch material, and it had to come from somewhere, you know?
Anyway, maybe you can get away with a flush for now and maybe you can't. Either way I think you're in for a new tranny very shortly. Sorry.
2005 Outback
END OF LINE
Old 08-16-2004, 01:52 PM
mtbikerco
yeah, I dropped it off at my mechanics today and he is going to let me know whats up, other than it doesn't work. I doubt I will be fixing it, dont have $$$ to spare for that without completely ruining my plans for the future (moving to New Zealand).
Old 08-16-2004, 04:12 PM
Moderator
Oh, well...crap - you're not going to take the car with you to NZ anyway.
2005 Outback
END OF LINE
Old 08-16-2004, 04:33 PM
mtbikerco
no, but i needed at least 2500 out of it when i was going to sell it before i moved, also NEEDED it to last till i moved. Now neither is going to happen... leave it to the SVX to &%$# YOU.
Old 08-16-2004, 04:45 PM
Moderator
Well, it is after all a complicated 12-year-old car. It's not a Camry.
2005 Outback
END OF LINE
Old 08-16-2004, 04:53 PM
mine's 13yo.
Display Modes
