4eat vs 5/6 spd sticks
Quick question - food for thought...
How do the 5/6 spd sticks control 'torque split'? I don't remember reading about this in previous posts. Do the sticks have clutch packs like the 4eat? Or does it use a viscous diff? Does the 'torque split' vary? Does that give the 4eat an 'advantage' over the sticks? Just curious! Feedback? Thanks, mile-hi-bri |
Hi Brian, the standard WRX manual trannys use a standard 50:50 differential with a viscous coupler. If the viscous coupler detects a speed difference between the front and rear drivelines, then it more strongly couples the front and rear. The system is designed to try its best to maintain a 50:50 split while allowing some differential rpm in the front and rear drivelines.
The WRX STi 6MT has a center diff with a variable torque split. The torque split can be varied by a computer, or it can be manually controlled. I don't know for sure, but I imagine the diff also has a viscous coupler. My feeling is that the SVX 4eat has a more desireable power distribution scheme. I just would have preferred that the rear wheels be the ones that are always driven, and the torque to the front be variable. This is how its done on Skylines.
Andy ------------------------------------------------------------------------------------ If I would be a young man again and had to decide how to make my living, I would not try to become a scientist or scholar or teacher. I would rather choose to be a plumber or a peddler in the hope to find that modest degree of independence still available under present circumstances. -- Albert Einstein, The Reporter, November 18 1954 |
How a viscous coupling works:
http://auto.howstuffworks.com/differential7.htm Quite similar to a torque converter, actually...
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
