Old 01-22-2004, 08:24 PM
Paxton71
Is this the tranny cooler and filter kit?
My Dad (The "RudeMaster") tossed me a box of parts when he sold me the SVX. "Here, I didn't have time to put these on."
Is this the campaign set?
Anyone have pics/instructions on where stuff goes?
Anyone going to be at the East Rocky Slope BBQ with this stuff attached to their rig so I can take pictures?
Thanks!
(love the floppy sock)
[EDIT]
I saw where the filter goes. What about the external cooler? How to plumb it?
[/EDIT]
Old 01-23-2004, 08:49 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Is this the tranny cooler and filter kit?
Thanks!
[EDIT]
[/EDIT]
The filter is the campaign filter. The cooler is actually the POWER STEERING cooler. IF you look underneath, the lines coming into the passengers side of the radiator are the lines into the cooler. You'll have to loosen the radiator and raise it up a bit to be able to remove it. Be careful. When I went to change mine, the bolts were rusted and I snapped the head off both of them. Now,the cooler is just sitting in there, until I can find the time to try and drill the bolts. out.
Randy Johnson
Mike Davis -- at Reading VI
Old 01-23-2004, 11:18 AM
Paxton71
Thanks Randy. Plumbing for campaign kit?
Great! That helps a bunch.
I wonder why the "RudeMAster" has one to replace...I saw that one down there and it looks ok...
Ah, I think he replaced the steering rack once... I bet he just said, "give me all the lines and stuff for the power steering."
I know he replaced the radiator once too...maybe that is when/why he got the spare.
At any rate, anyone have the plumbing route for the campaign kit?
Thanks everyone.
-pax
Old 01-23-2004, 06:06 PM
The Molinator
CAMPAIGN filter
My campaign filter is mounted to existing bolts. The lines are connected in series I believe to the lines going to the radiator AT cooler (at bottom). I'll try to shoot pics of mine, but don't know when. Check How-To and search lockers for info >> I think you'll find what you need!
Jim
Old 01-24-2004, 12:25 AM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
I'm almost positive its in the how-to locker
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 01-25-2004, 10:38 AM
Paxton71
Filter kit
I talked to the Rudemaster who explained, "I couldn't figure out where it went!" Sure enough, the bracket I have is different than the bracket in the how-to-pictures. There isn't much for instructions, but Beav's old posts helped out a lot.
I think my kit is for a legacy. I think I can modify the bracket I have by welding it to the tow hook. It'll be just fine.
First, Off to the store for supplies and stuff.
-Thanks, PAX
Old 01-26-2004, 09:19 AM
Aredubjay's Avatar
Re: Filter kit
-Thanks, PAX
You might try PM'ing svxcommuter. I think he retrofitted the Legacy filter to the SVX, but, I'm not sure. I know SOMEONE did.
Randy Johnson
