Old 10-27-2003, 04:53 PM
92black svx
Help
hello i have a 92 svx and when its wet out the front tires will spin then the back makes like a grinding noise and kicks in i already have the adative in from gmdealer so what could it beplease help me to solve my problem i really like this car
Old 10-27-2003, 05:51 PM
wawazat??'s Avatar
Yeah, I'm still around
Unhappy Trans problems
Transfer clutches or worse. Sorry.....
Todd
Down to none
Old 10-27-2003, 06:15 PM
Wiz Wiz is offline
Send a message via ICQ to Wiz Send a message via AIM to Wiz Send a message via Yahoo to Wiz
Re: Trans problems
Does it shudder when driving sometimes? Like when you give it gas and let off? Mine did that a day after I got it and then a few days later when I was having it checked out I found out my rear tires wernt working. Rear berings and tranfer clutches went. Its still in the shop... I hope to have it back tomorrow.
I hope your car does not suffer the same fate as mine did. Its expensive.
Green 1994 SVX LSi - Totaled by a plow. RIP
Bordeaux Pearl 1994 SVX LSi - 182k
Old 10-27-2003, 06:18 PM
92black svx
i just replaced rear bearings a few monthes ago the rear wheels r working cause u can feel them move in the rain i was wondering if any one thinks that it could be the bushing in the rear sway bar
Old 10-27-2003, 08:42 PM
nordique14's Avatar
nordique14 nordique14 is offline
Who watches the watchmen?
If it's making a grinding noise, it won't a sway bar bushing problem. If a bolt holding the sway bar bushings has fallen off, it causes more of a clunk sound. You should be able to easily see the sway bars if you look underneath the car. A more common sway bar bushing problem is that they will make a creaking noice going over a speed bump. A little lube will mkae things better that (just make sure they put all the bolts in properly).
