Old 05-24-2003, 06:24 PM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
Heat Shields
i believe that my rattle is from the heat shields
if it's the resonator after i remove the shields i'll deal
what size are those bolts on the shields
they seem to be 13/32nds
10mm is too small, 11mm is too big
7/16 is too big
3/8 is too small
that leaves that in the middle
and the ones on the manifold seem to be 15/32nds
can anyone confim, i'm gonna go hit it w/ wd40.... see if i can loosen them up
SV What?
Old 05-24-2003, 06:53 PM
Subafreak's Avatar
Superbeast
I belive the correct size is, cut-off wheel and pry-bar. Really.
The original size was 10mm, but at this point don't expect to acctually unbolt them.
Old 05-24-2003, 06:57 PM
NomadTW's Avatar
hmm cutoff wheel
good idea
i'l have to try that another day...
it's getting dark now
prybar i knew they're tacked together right?
SV What?
