Old 08-16-2001, 05:53 PM
svxwrx
Annyoying Problems!
Has anyone had trouble with the front window washer fluid on the SVX. None will come out when i press on the button, but the wipers still move. I checked in the pipe to see if it was leaking, but still nothing. Any suggestions, and the 2 holes at the top are not clogged i just stuck a thin needle down them to make sure of it. Also I was wondering if any people were having trouble with their CEL. Could it be the 02 sensor? Thanks
Old 08-16-2001, 09:52 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Annyoying Problems!
Is the pump working? Does it buzz when you press the button. It may be shot, or just clogged. Sometimes "gunk" gets into the screen. Also, the connectors to the pump, going into the reservoir could simply be oxydized -- might try cleaning them first.
Of course, I have a brand new washer pump in my trunk -- still in the box -- from where I kept pulling back on the stalk (mist function) thinking it was the wash function. When I figured it out, boy, did I feel foolish. Anyhoo, the pump is relatively inexpensive. They have them at Autozone for about five bucks. I'm sorry, but, I don't understand the term "CEL" -- can't help you there.
Randy Johnson
Mike Davis -- at Reading VI
Old 08-17-2001, 12:02 AM
svxwrx
thanks for the advice man. i just figured it out, the fuse near the bottom of the washer fluid box was not plugged in.
Old 08-17-2001, 06:56 AM
eddycat2000's Avatar
eddycat2000 eddycat2000 is offline
Dumba$$ Mechanic
Re: Re: Annyoying Problems!
I just assumed he meant Check Engine Light. BTW-don't feel bad about the washer thing...I've had to edjacate more than a few people on that one. (Why is it that people will pay 30k for a car and not spend a few hours perusing the owners manual?)
Pull my finger!
Old 08-17-2001, 07:19 AM
cocacola08's Avatar
cocacola08 cocacola08 is offline
This account is scheduled to be deleted for inactivity
Send a message via ICQ to cocacola08 Send a message via AIM to cocacola08 Send a message via Yahoo to cocacola08
Eddy
Just kinda curious here, but is the O2 sensor in anyway assoc. w/washer fluid?
Kev
kevin.m.sheets@verizon.net
Old 08-17-2001, 07:26 AM
Dumba$$ Mechanic
Originally posted by cocacola08
Eddy
Now don't take this the wrong way, cause I'm just teasing you...I've always heard that there are no toopid questions, only toopid answers. But I think you may have just changed my mind on that theory.
Pull my finger!
Old 08-17-2001, 09:08 AM
nvrmore100's Avatar
nvrmore100 nvrmore100 is offline
Send a message via AIM to nvrmore100 Send a message via Yahoo to nvrmore100
Re: Re: Re: Annyoying Problems!
You don't even want to know what I read that as first...stop typing things like that guys...it's early...
Ryan
92 LS-L Claret / Black UR Underdrive Pulley, Bosche Platinum +4 Plugs, K&N Cone Filter
http://www.ryanmacdonald.com
http://www.digitalvertigo.net
http://www.open-innovations.com
Old 08-17-2001, 09:14 AM
Dumba$$ Mechanic
Re: Re: Re: Re: Annyoying Problems!
Ryan
Well, I kind of figgered yer mind was in the gutter, but now you've removed all doubt.
Pull my finger!
Old 08-17-2001, 06:14 PM
Aredubjay's Avatar
Trouble is, I had read the owner's manual. The first day I had the car, I sat on the . . . uh . . . in the library and read it cover to cover. Y'know how, when you sit and read a long time and you go to stand up and you can't feel your legs? Well, anyway . . . it had just been too long between the time I read it and the time I needed them.
Randy Johnson
