Old 02-18-2008, 04:19 PM
dennyo dennyo is offline
separator cover leak
I've noticed a few people mention rear main seal leaks and the oil dripping on the head pipes creating smoke.I'm wondering if an oil separator leak would do the same thing.And also why is it called a separator if it just is an access cover.What does it separate?Might sound like a dumb ? but I'm curious.Any help anyone? I believe mine may be leaking as well as there is oil on the crossmember but is so slight it's hard to call it a leak.Maybe the beginning of a main seal leak
Old 02-18-2008, 04:48 PM
the seperator cover covers not only the piston pin access port but it also acts as a seperator for the PCV system. inside there is room for oil to get to the bottom while air escapes to the top
Old 02-19-2008, 06:40 AM
thanks tom.Almost sounds more like a baffle than a cover.
Old 02-19-2008, 06:41 AM
essentially that is what it is.
Old 02-19-2008, 10:53 AM
AFBeefcake's Avatar
AFBeefcake AFBeefcake is offline
Subaru Swapper
Send a message via AIM to AFBeefcake
Mine was leaking bad. I replaced it with a new metel one and the leak stopped.
2005 Legacy GT
2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles
My WRX's Cardomain Page
Old 02-20-2008, 10:09 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Do you have to pull the engine to replace it.
1995 POLO LSI 76K MILES SOLD
Old 02-20-2008, 10:36 AM
Hondasucks's Avatar
Subaru Technician
No, you can also pull the tranny to replace it, that's usually how we do it at work. Takes about 45 minutes if you have a lift and are good at it...
1986 VW Jetta
Old 02-20-2008, 10:45 AM
svx_commuter's Avatar
It is part of the PCV system. The positive crank case ventlation pulls blow by gas and oil out of the crank case. It keeps the crank case at low pressure (as long as your foots off the throttle) The baffel separates the oil vapor from the air and gas before pulling it back into the engine. The oil drips back down into the crank case. The ait and blow by gas then gets pulled into the intake manifold and burned. I think it's is a nice design for the separation process.
There is a metal replacement? That would be good.
Take cae of that SVX,
John
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 02-20-2008, 01:27 PM
45 minutes to drop the tranny and replace the cover?That seems pretty quick to me.
Old 02-20-2008, 05:41 PM
kwren's Avatar
kwren kwren is offline
That would explain the...
"and are good at it" thing
Old 02-20-2008, 11:08 PM
Hondasucks's Avatar
Subaru Technician
When you have it up in the air, have a tranny jack, and air tools it's pretty easy. The only hard part is the %$*%*$& torque converter bolts, shoot it took me longer to get those out than it did to do the rest of the crap to get the tranny out! I've seen the Master Tech that I work next to do it pretty quickly, although now that I think about it, I think the one I saw him do in an hour was a manual, more like an hour and a half for an automatic.
Cuz if you think about it, to take the trans out, you drop the exhaust, drop the drive shaft, undo the linkage, take out the crossmember, undo the bellhousing bolts, and it's out, and on an automatic you have the cooler lines and torque converter bolts. Not really that hard if you have a lift, sucks doing it on your back though. (Been there, done that with a Ford Taurus.. NOT FUN)
1986 VW Jetta
Old 02-21-2008, 02:28 PM
Any idea what a dealer might get for doing it?I realize prices will be different around the country but assuming 75-85 bucks an hour what could I expect to pay ,worst case scenario?
Old 02-21-2008, 06:23 PM
Hondasucks's Avatar
Subaru Technician
Last one we did that I saw the RO, it was like $550, sucky thing is that's all labor, since the part is like $20. Probably a good idea to throw a rear main in there while you're at it, that'd be another $40ish.
1986 VW Jetta
Old 02-23-2008, 02:49 PM
Thanks to all. Do the head pipes and all 3 cats have to get dropped or just the front to provide clearance? I ask because I'm wondering what other parts I'll need.like exhaust gaskets, hangers, etc. I would like to have as many on hand so I don't need to have the dealer order them or the downtime.Any help?
