Old 06-27-2001, 12:06 AM
KEVINL
Part #'s needed
I need the part #'s for the rear diff mount bushings for a 1992 SVX
and the external transmission filter
Old 06-27-2001, 06:23 PM
Chad
Part #'s
One place you might look is subaruparts.com
It has helped me out.
www.subaruparts.com/accessories.php
Old 06-27-2001, 08:51 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Part #'s needed
If you haven't found them by the time I get to work tomorrow, I'll look them up for you then.
Randy Johnson
Mike Davis -- at Reading VI
Old 06-28-2001, 09:55 AM
Aredubjay's Avatar
Re: Re: Part #'s needed
Part # for the right is 41322AA010, Left is the same. ATF filter kit is 31099AA091. Did you need the retainer bushings also: Lower, both right and left are 41324PA000, and upper, both right and left are 41324PA010.
Randy Johnson
Old 06-28-2001, 11:26 AM
KEVINL
Thanks for the numbers what are the retainer bushings
Old 06-28-2001, 11:41 AM
Aredubjay's Avatar
They are the "caps" that go on top of and under the bushing that fits in the differential cross member.
Randy Johnson
Old 06-28-2001, 11:18 PM
KEVINL
couple of questions are these part numbers for one only meaning I need to order 2 of each except the trans filter
BTW 41324PA010 is not a valid part number
Old 06-28-2001, 11:26 PM
Aredubjay's Avatar
You are correct, sir. There is a right and left for each of the parts.
Don't understand why they wouldn't recognize that part number, unless they've discontinued it. I took it directly from the OE parts catalogue for the 92-94 SVX. Hmmmm.
Randy Johnson
Old 06-29-2001, 12:18 AM
KEVINL
Thanks for your help
Old 06-29-2001, 07:57 AM
Aredubjay's Avatar
Always a pleasure. Any time.
Randy Johnson
Old 06-29-2001, 08:14 AM
Aredubjay's Avatar
Kevin,
It's been brought to my attention that I may have been misunderstanding the part numbers you actually need. Go here:
http://y42.briefcase.yahoo.com/bc/ku...c=bc%26.view=l
And check out the diagram with part numbers. Also, theres a wealth of other info on the rear diff mounts. Sorry if I led you astray.
(Thanks Kuo! )
Randy Johnson
Old 06-29-2001, 11:36 PM
KEVINL
I need the mount shown in the picture with the yellow box circling them my Rwd conversion finished them off
Old 06-30-2001, 12:20 PM
Aredubjay's Avatar
Then, yes, I lead you astray. I was giving you the pn's for the crossmember bushings (but it was the only thing in my catalogue listed as diff mount bushings). My catalogue doesn't have the trans and diff diagram for some reason. the PN for the diff mounts that you need are on the diagram in Kuo's briefcase.
Randy Johnson
Old 06-30-2001, 01:42 PM
zsvx
might as well use the same thread...
I'm looking for the part numbers for the front tow hooks. I can't find these anywhere on subaruparts.com (of course I found a bunch of other stuff to spend money on there )
Old 06-30-2001, 04:58 PM
Aredubjay's Avatar
Re: might as well use the same thread...
My catalogue is at the office. I'll look them up for you Monday, unless someone else posts before then . . . that is, if they're available. I need mine straightened.
Randy Johnson
