#91
-Bill p.s. I'm wondering if a little less retard on the timing + little more duration might bring some bottom end back in and punch the top end up a bit more...
#92
yeah... I was thinking something around there... More about the duration than anything... I am not sure yet but I am liking the odds
Tom |
#93
If peak power is being made at 6,100rpms, then we'll have some room to work with. But if peak power is made at a lofty 6,800rpms, then we shouldn't raise it any higher as we may run into issues such as 'valve float' in those higher rev ranges (due to the increase in intake valve lift). Depending on Harvey's input, maybe the 5/6MT guys can try the same specs (8.0mm lift, 247 degrees of duration) but without retarding the profile by 7 degrees??? I know Harvey came up with those final specs in the way he did, to keep the IRIS system functional. -Chike
#94
Guess we'll either have to get your car or Tom's 5spd down to the dyno to see were the peak is! That, or wait until I have the cams installed...
-Bill
#95
-Chike
#96
So there's no noticeable change in fuel consumption with these cams. -Chike
#97
The set up that Chike used, was to suit the 4.44 auto that he uses to run the quarter, as there was going to be some low rev power loss from the IRIS, it would only be below 3500, on the run up in first gear, and as the power drops after 5700, it was better to move the lobe center higher to fully use the top end, between 5500/6500. With this end of the range pulling harder, there is more power over the rev range that he uses on the strip, 3500 to auto change 6800. I don't reconmend others use this lobe center setting. If the car has a 3.55 auto, it should use the standard 116*. If it has a 4.11 auto/ 3.9, 4.11 manual, then you could go to 118*. The duration and lift remains the same, you just need to tell Scott what lobe setting you want, when he does them. Harvey.
#98
Harvey:
So, if I have a 5MT with a 3.9 ratio and I am looking for maximum performance on a road track (not AutoX), with top speeds of maybe 110-120 mph, but only getting down to 2nd gear, what lobe center setting should I ask for? Thanks.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#99
Here are a couple pics of my cam install without taking the engine out
wtf why can I not add images to the post??? eh here is a link to Mike621's locker where the pics are Linky link linker Tom |
#100
isnt 3.9 the stock final drive? thats why i ask thanks |
#101
Yes. The 3.9 would be a WRX 5MT, which is what I am planning to have by next summer. As I understand it, the rear drive shaft from the WRX transmission is underdriven, so that it can be used with the stock SVX rear differential, and be consistent with the 3.9 ratio on the WRX front differential.
#102
#103
Earthworm:
thanks
#104
would porting the heads net some more power with these cams? Is it possible that the ports flow good enough already and the bottle neck is at the valve opening making a port job useless. Does this make any sense? Anyone?
EG33 Turbo Porsche 914 |
#105
Of course OBI, the secret of performance begins by flow. either air flow, or fuel flow or water (cooling) flow, they all contribute to the increase in power.
I have been told by many tuners that plated valves (we call it chrome plated, I dunno if it is actually chrome) ease up the flow of fuel and do not form sludge on them. There wouldn't be loss of fuel which leads to higher compression caused by the combustion of a greater amount of fuel injected (remember no loss). What I am really interested in is rather can we shorten the ports leading to an even faster flow through the valves? I am asking this question because I read like 6 years ago about the superiority of Mercedes Benz's 99' E320 engine, having direct injection in the combustion chamber... or directly above the valve... sorry I do not recall...
