Old 02-04-2011, 05:38 AM
gsrsol84mm gsrsol84mm is offline
Where Can I get A New Alternator Plug ?
Would appreciate any help as to where I can find a new alternator plug ? The wires in mine have become brittle and are showing, causing all the lights to flicker. Thanks
Old 02-04-2011, 06:40 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: Where Can I get A New Alternator Plug
I think John "svxcess" found a source for these? If he doesn't reply here send him a PM.
Old 02-04-2011, 09:42 AM
Manarius's Avatar
Manarius Manarius is offline
Soldering iron, solder, and some new wire would probably save you the hassle of having to buy a new plug.
-Jason
-Obi Wan Kenobi
Old 02-05-2011, 03:38 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: Whan Can I get A New Alternator Plug
Find a place that rebuilds alternators, they usually have spares lying around.
That's how I got one.
Old 02-07-2011, 11:58 AM
BoxerFanatic's Avatar
These are the plastic plugs on the passenger side of the alternator, for the voltage regulator, right?
Mine is intact, but pretty well baked brittle, and the wiring insulation is similarly brittle and splitting.
I am having to charge the battery with an external charger every 2-3 days or so. (new battery last month...)
I am thinking it might be approaching the time to get a re-built up-rated alternator, and do the wiring upgrade mod. a new voltage regulator plug would probably go along with that.
Do the plugs come with a wiring pigtail to splice into the existing wiring, or does the plug require wiring to be pinned and installed into the plug?
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 02-07-2011, 12:33 PM
Do the plugs come with a wiring pigtail to splice into the existing wiring?
Yes. they have about 3-4" of wire attached. Just mark or disconnect one at a time to avoid confusion. The original plug wires are two different thicknesses, while the replacement plug wires are both the same size
Old 09-09-2011, 03:09 PM
Just wanted to bump this thread to thank John “svxcess” for all the helpful information on this topic.
The alternator went out, as well as a tire going flat, so the SVX has been waiting for me to assemble some money to fix it. Now the money is assembled, so I am assembling parts.
A new Maniac alternator, a Littelfuse holder and fuse, and a regulator plug replacement are all on order, and tires will be soon, too, to get back on the road properly, and reliably.
The information thread on the electrical repair/upgrade procedure has been invaluable, thanks again.
Old 12-04-2018, 11:04 PM
Re: Where Can I get A New Alternator Plug?
Call Christian at Maniac Electric Motors in Dallas, TX.
214-202-3250
Mon-Fri 9:00AM-3:00PM CST
https://www.maniacelectricmotors.com/spalplhap.html
Also available on Amazon.com for only $9.98 and free shipping.
https://www.amazon.com/S-P-ALTERNATO.../dp/B00AY1ZU0A
File Type: jpeg C090AB4F-B942-4C36-8182-BCB7FDC9D244.jpeg (26.3 KB, 561 views)
