Mounting Alcyone hood ornament
OK guys I just got my Alcyone hood ornament but my car has no holes in the hood remaining from the old emblem.... and no sign of where it once was. Any suggestions on how to install one of these from scratch. Looks like I'm going to have to drill three holes in my hood (not good). Two of the posts have pyramidal rubber washer type things, the third is just a steel post. What drill bit and do you just push the rubber washer type things through the steel hood or is there some trick to the whole thing...
I know it's probably simple but I'm new to this and not real handy when it comes to these things... Rather do it right than make cheese out of my hood... Thanks
94 SVX LSI 2001 LegacyGT (daughter's ride now) 2005 Legacy outback XT (wife's car) all stock and likely staying that way for now 1981 Datsun 280zxturbo summer toy |
Well...not having seen the reverse side of the alcyone emblem, I can only offer some common sence advice stemming from my fabrication experiances.
First thing's first...find the center line of the hood. Get a tape measure, and go right across the front edge of the hood....thake the measurement, half it, and use that measurement to make a pencil mark on the center of the front edge of the hood. now you have something to work with. you'll have to do the same to the reverse side of the emblem. All measurements from this point should be from that mark. Its jsut a matter of masuring and plotting. Or, you can do it the bodyshop way, and break the mounting studs off the back, eye it up (Doesnt matter if the emblem is upside down, or on the wrong car for that matter) and stick it on The later of the two isnt reccomended
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
Any pics of the back side of the alcyone badge? I was thinking about doing the same thing......
-Ryu Links: 2004 Honda S2000 (2008~) 1992 Subaru SVX LSL Liquid Silver (2007~2008) 1996 SVX LSi Bordeaux Pearl (2006~) 2002 Lexus IS300 Sportcross (2005~) 1992 Subaru SVX LSL Pearl White (2001~2005) 1994 Mercury Sable GS (1999~2001) 1/43 Scale SVX Models [SIGPIC][/SIGPIC] |
are you guys sure.?>.when you pry off the stock badge. the badge should be held on by double sided tape and two prongs i believe it was if not three..but there is a yellow plastic thing-which you should see on your alcyone badge as well...take those out and your alycone badge should go right in...
if that's not the case...then i'm not sure
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
he may not have a stock hood so the holes might not exist.
I just did this on my '92... Here's what I've got:
When I removed my stock badge, there were three holes - two side by side (where the prongs with the yellow plastic jobbies went), and one below them (for alignment and anti-upside-down purposes). Conveniently, when you have the holes, it's nice 'n' easy to line it up, press it on, and admire your work. I think '59 is telling us that there are no hood holes to work with? Seems odd; why would they change that? Alas, when there are no holes for badges, manufacturers usually have tools that touch the car in a few places to perform alignment before pressing the badge on. Looks like there's little choice but to measure well?
DO NOT TAKE THE YELLOW PIECES OFF THE EMBLEM. After cleaning the hood of grease or wax, peel off the protective backing from the emblem. Once you line up the pins with the holes in the hood, press the pins (and yellow rings) into the holes as far as they will go. Then use firm pressure all around the emblem to make sure the adhesive gasket is secure. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 05-08-2007 at 06:30 AM. |
