Old 11-18-2012, 04:44 AM
95greensvx's Avatar
95greensvx 95greensvx is offline
Transmission noise
I was heading to work in the morning with my 95 awd automatic with 220k and when I accelerated from a stop I heard a clunking sound. At first it sounded like something could have been loose like an axle popping out and not engaging. I took it home and checked out it later. When I drive at a very slow speed regardless of drive or reverse it will move and then feels almost like the Park is trying to re-engage. If I drift really slow it will move forward, then make the clunk and stop for a split second, then go again and will do it all over again. I'm not sure exactly what the problem is and any help is appreciated.
06 Ford F150 Crew 4x4 142K+ miles
05 Volvo XC90 163K+ miles
02 Toyota Camry 170k+ miles
Old 11-18-2012, 08:32 AM
dcarrb dcarrb is offline
Re: Transmission noise
If that happened to me, my first guess would be the front differential has tanked.
dcb
Old 11-18-2012, 09:47 AM
Yep, front diff. Drain the oil and look for a nice lil tooth stuck to the drain plug
Old 11-18-2012, 10:12 AM
michael's Avatar
michael michael is offline
What Potholes ???
I've heard of axles popping out, For me it was a front diff tho GL
Wanted: Steering Wheel
Old 11-19-2012, 09:30 AM
95greensvx's Avatar
Thank you for the replies, I am assuming it is the front differential. I will examine it at some point in the future when I have time to do so.
Old 11-19-2012, 10:05 AM
gbianchi gbianchi is offline
Why so many diff failures on SVX, diff gears are some of the most hardy parts of any car or should be, never had one fail, just curious. Good day all ..........G
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 11-19-2012, 10:21 AM
95greensvx's Avatar
Given that there may also be a problem with my transmission itself depending upon what exactly failed in the front differential I have read on here that the 4.44 transmission is a good choice to swap to. Which subaru's carried that transmission so I can start searching for prices to get an idea as to what I will end up spending to repair my svx?
