Little help, Parent's Forrester won't start.
it's a '98 forrester, factory alarm(which im not sure is related)
this morning my dad went to take it out and the just just wouldnt turn, ive tried everything, lock/unlock, lock/unlock w/ remote, steering wheel lock, pressing brakes, pressing internal disarm for alarm, they just wont turn period, any ideas? |
It would help if you told us what a "just just" is.
Maybe disconnect the battery for a while to reset it if it is an alarm issue?
Have you checked the fuses and fusible links?
Yeeeaaaaahhh, I'm with Beav on this one - we need better clarification before we can help you out.
But if everything seems okay, and the engine just won't turn over, you probably just need a new battery.
i'll try disconnecting the battery, i had checked the fuses and they were fine, see the problem is the key will go into the slotbut it wont rotate anywhere from locked, not even into accesory
You might wanna check and see if the steering wheel is locked. Jiggle the wheel and turn the key and see if it unlocks.
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
