Old 07-03-2006, 10:10 AM
curly2k3's Avatar
curly2k3 curly2k3 is offline
Own'eded
Send a message via AIM to curly2k3 Send a message via MSN to curly2k3
NOS users... question for you
what kit are you using?
what jets are you using?
have any of you ever used the ZEX kit?
is the install really that easy?
thanks, just some basic info needed... I am getting a ZEX kit for 150 complete so... yeah
98 Impreza Wago-O-Doom & Datsun Roadsters
Old 07-05-2006, 08:47 AM
poweredx2 poweredx2 is offline
zex is about the best bang for the buck,do not forget to upgrade your fpr or you will be burst vacuum lines with anything over a 75 shot.
Old 07-05-2006, 09:39 AM
A few questions for you...
Wet or dry kit?
What jets are you planning on running?
What does your exhaust look like?
Have you done your homework on the operations and dangers of N20?(trust me, I did this and it helps you understand how it works and why it works much better)
Old 07-05-2006, 09:47 AM
curly2k3's Avatar
Own'eded
Wet or dry kit? ~Dry
What jets are you planning on running? ~55 shot only
What does your exhaust look like? ~shot for now, all new in 2 weeks tho
Have you done your homework on the operations and dangers of N20?(trust me, I did this and it helps you understand how it works and why it works much better) ~yes I have, and I was going to ask you actually, which plugs should I run, I know its supposed to be a colder plug... but which for a small dose?
Old 07-05-2006, 02:30 PM
Most people on this board use iridiums,but I have used autolites nonresistor on nos for years,also with a small shot like that you don't need to switch plugs,I RAN bosch plugs plus 4s with a 75 shot not recommended for you,go the safe route.
Old 07-05-2006, 03:46 PM
curly2k3's Avatar
Own'eded
alright, I run platinum tipped bosch... they're 10 bucks a piece but they work great... I will plumb it all up and them charge the bottle... then I will compare before to after on the strip...
this whole thing came about because me and my friend want to race the legal way, he has a 455 big block delta 88 and it was going to be a stock vs. stock race, but he put on an edlebrock intake and holly 4 barrel carb... as well as some other small things, so I am just re-evening the origonal race before I might turbo the car... so I am going to do the ZEX nos kit, small intake stuff, exhaust and a new ECUtune chip... not sure which yet tho...
Old 07-05-2006, 03:52 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
with NO2 you need to run eather iridium (sp?) or copper plugs
- John
Old 07-05-2006, 06:14 PM
svxsubaru1's Avatar
svxsubaru1 svxsubaru1 is offline
Why not platinum, it would seem like running the right heat range and gap for a plug would be the only important part.
92 Honda CBR 600
95 Miata
Old 07-05-2006, 07:37 PM
curly2k3's Avatar
Own'eded
thats what my thoughts always were as well...
Old 07-05-2006, 07:46 PM
immortal_suby's Avatar
Thread Killah
I have the precats removed and just a high flow 2 into 1 cat then glasspack then flowmaster.
the main 2-1 cat I added in about 3 months ago and gained some low end power back when it went in. (Harvey was right .... again)
so - Tom/Jesse/Mike/Walter/etc.
should I remove the cat to run the ecutune stage 2 nitrous kit at @ 100hp or am I ok there with the cat.
I am too much of a chicken to run the 165 shot.
Locker Link
2015 BRZ Limited 6MT
Old 07-05-2006, 08:19 PM
SVXelerator SVXelerator is offline
Frequent User
rejet to a 100 shot and go for it!
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$
Old 07-05-2006, 09:25 PM
gotta cut the pre-cats to run the 165 I would suggest doing it for the 100shot as well, last thing you want is to melt the pre-cats and clog the exhaust
Old 07-05-2006, 11:00 PM
mbtoloczko's Avatar
sans SVX
The Magnaflow cat has a ceramic brick. The cat might turn cherry red, but you won't melt it. :-) I think you can leave it for a 100 HP shot. There are plenty of cars with 300 HP running cats without issue.
Mychailo
Visit my locker
Old 07-06-2006, 08:25 AM
curly2k3's Avatar
Own'eded
so general consensus again is stock plugs are fine for my app?
Old 07-06-2006, 09:55 AM
No Platinum!!! They will melt
