Dashboard switch question
Hi folks,
I just bought this from Japan - mainly because of the switch on the RHS - I have a blanking plate fitted in that position on my car. What is the purpose of the switch (door unlock ?) - also where in the service manuals might I find it, hence where to join it into my existing wiring loom. Thanks Steve in New Zealand.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Re: Dashboard switch question
Heard that was a disable switch for the JDM infrared door unlocking sensor (drivers side only feature)
"Peace is the flower of justice." |
Any more thoughts.....might have to check out Aus/NZ manual to confirm (alas i only have USA manuals).
Thanks.
Maybe a power window lock?
OK got the switch in my car - the only difference between my original wiring look connector and the new one is the extra white/red (along length of wire) I know it has to go into the OEM standard alarm - it is a bit like the "security" switch in USA models.
Anyone got a JDM/NZ/AUS wiring digram of door lock area that they could scan and send me?. TIA Steve
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 02-05-2016 at 01:45 PM. |
