Re: Oil filter revisited
EDIT So I found that chapter in the FSM and discovered a few tidbits. First, and foremost, they specify a filter with a 23psi bypass!!!!!!!! So the filters that some books/websites suggest for our car have BPVs that are actually too low and the L30165 is acytually closer to what we want! I suggest looking into the BPV specs for the filters you are using. For example, Amazon AND the Purolator site both suggest the Purolator L14459 for the SVX whereas the L14460 is actually the filter with the correct bypass pressure. They are physically identical in terms of form and fit. I believe the Bosch 3312 also has a lower bypass pressure. I am not sure about the others. And, again, I'm not sure how much any of this matters. But, if it does, we probably should identify the filters that fit and have the proper BPV rating. I also now have some pump specifications to work with. And, of course, I have the schematic of the flow. I will do some playing at lunch time with excel!
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 08-28-2013 at 09:27 AM. |
Tom,
I almost have the spreadsheet done. I only need an estimate of the engine's resistance to oil flow. If you can give me your pressure readings a couple of different RPMs and give me a rough guess at the oil temp and tell me what oil you are using, I can estimate the flow resistance. Tony I'll tell you what, this really shows one reason why it is downright idiotic to romp on your car when it is still running cold in the winter. Oil does not flow well at 0C and below and you quickly reach the pump's capacity for generating the pressure needed to get the desired flow rate. Add that to other factors like metal parts still being highly contracted, leading to lower pressure on certain gaskets and seals, and you really risk causing some damage by beating on a cold car.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Find the bottom of a long, steep hill. Park your car at the bottom, facing the hill, on a night where it will get below zero. The next morning, get in, start the engine and immediate floor it. Repeat until a rod comes through the block.
Here is a plot of typical freezing point pressure drops across a variety of filters, similar to the oversized filter we use. It is for a generic 5W30 oil. I believe the Ultragaurd filter used is/was a synthetic filter similar to what you now find in Amsoil, Royal Purple and the synthetic Purolator filters.
I looked it up actually because I was curious. "gallery" is correct, and "galley" is probably a misspelling/contraction that became widely used.
Least fun "fun fact" ever, I know.
I will get you those numbers but I have to replace the gauge first. Apparently hard mounting of a mechanical oil pressure gauge on a supercharged engine does not lend itself to long gauge life. sigh I can tell you this, before the engine warms up the pressure is SPECTACULAR! As I remember about 90 psi with a cold engine and (after the oil pump mod) 20 psi when warm at idle. More on this later...
Is the supercharger in the oil path? If so, where?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 08-30-2013 at 08:06 AM. |
Am I interpeting this graph correctly? At 3 gpm, the Ultraguard has 7.5 psid, while the Toughguard has 42 psid?
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
Yeah. Crazy, isn't it? I think, in the end, the engine has so much more resistance that the filter or its BPV pressure will matter much. At cold temps, flow will suck and the pump will be maxed out. At operating temps, the pressure required is well below the capacity of the positive diplacement pump so flow should be unaffected. I suppose a good flowing filter with a low bypass pressure will get full flow at a lower temperature. But that's about it.
[QUOTE=Huskymaniac;727813]Based on the calculations I did, I don't doubt the pressure was pretty spectacular. And that pressure was AFTER the filter. It only showed you the pressure drop across the engine. Imagine the pressure at the pump outlet! I am actually surprised you read 90psi at idle. The service manual implies that the max pressure available from the pump at low RPMs is pretty limited. Maybe those aren't actually max pressure values but desired or expected pressure values when operating at high temperature.
Is the supercharger in the oil path? If so, where?[/QUOTE] OK, bought and installed another oil pressure gauge today and just now installed it, put the battery on charge and should be able to get you numbers in the morning, Maybe by NOON!
#28
Ambiant temp 69------70------70------70------72------72------74------76
Time 11:28---11:31---11:33---11:34---11:36---11:37---11:39---11:42 Engine temp 63°f---118°f---135°f---149°f---156°f---178°f---183°f---208°f RPM 1350----1150----1050----1000----1000----1050----1100---1175 Oil PSI 87-------80-------60------50------40------30------25------20
#29
#30
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 09-04-2013 at 11:13 AM. |
