Old 11-23-2008, 10:54 AM
wawazat??'s Avatar
Yeah, I'm still around
Wix oil filter number
When Tom finished up my car recently I changed the oil for the first time in too many years to recall (5 I believe, car sat in the garage). I bought a Wix filter for the Porsche 944 (tall cannister, correct thread) and the part number for that filter is 51287. Expensive little bugger though at $14.00.
Todd
Down to none
Old 11-25-2008, 01:14 AM
kwren's Avatar
kwren kwren is offline
Re: Wix oil filter number
purolator is a great one and the # is L30165.
I bought a dozen of they on the web for a steel a while back I will look for the source. The company had a special for a certain zip code and when you went to the site it asked for your zip. That got me to the price that saved me about $10 each filter.
For the shipping address I simply put in my correct address, unrelated to the previous zip I entered, and it worked like a dream!!
Some others did the same thing so maybe some one has the information on it. I will see if I can find it.
Old 11-25-2008, 03:11 AM
kwren's Avatar
try this (Porsche)
Purolator Oil Filter
http://www.partsamerica.com/ProductD...tNumber=L30165
$6.96 each with Zip 17929
Old 11-25-2008, 10:53 PM
I just ordered 12 of them and it worked fine for me too.
Old 11-26-2008, 12:24 AM
kwren's Avatar
Great!............
Old 12-12-2008, 07:57 PM
liamrh's Avatar
liamrh liamrh is offline
Thread NECRO!!
Just thought I would add after doing some more research.
well... after an exhausting search through damn near every Wix filter availiable, then cross-referencing those to Purolator PN's.. I have found the following as the best candidates..
First, the stock specs:
Wix: 51334 (Purolator: L14460)
Size: HxOD = 3.2in. x 3.3in.
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Max Flow Rate: 9-11 GPM
Nominal Micro Rating: 19
Gasket Diameters
O.D.= 2.5in.
I.D. = 2.2in.
The specs from the "oversized" one I WAS using:
Wix: 51344 (Purolator: L24458)
Size: HxOD = 4.1in. x 3.2in.
Gasket Diameters
O.D.= 2.5in.
I.D. = 2.2in.
And now the ones I am hoping to use:
1:
Wix: 51285 (Purolator: L30251)
Size: HxOD = 5.8in. x 3.0in.
By-Pass Valve Setting-PSI: 30
Nominal Micro Rating: 32
Gasket Diameters
O.D.= 2.7in.
I.D. = 2.4in.
2:
Wix: 51287 (Purolator: L30165) A shorter version of above
Size: HxOD = 4.8in. x 2.9in.
By-Pass Valve Setting-PSI: 27-33
Gasket Diameters
O.D.= 2.7in.
I.D. = 2.4in.
http://forums.nasioc.com/forums/show...=891014&page=2
Also,
http://www.ntpog.org/reviews/filters/old_filters.shtml
STockers
Looks like the M-105 would fit also as an alternative to a large filter.
Old 12-12-2008, 09:22 PM
kwren's Avatar
Purolator L30251...
http://www.partsamerica.com/productd...tNumber=L30251 links right to the page. just put them in the cart at $8.68 each order a few $75 worth and get free shipping and no sales tax for most of us.
This is a really tall one...5.8 inches high... with twice the micro rating, 32 as opposed to 19... what ever that means... Sounds better to me!
Old 12-12-2008, 09:34 PM
liamrh's Avatar
A sock and some twist ties are pretty cheap if that is what your looking for.
Old 12-12-2008, 11:13 PM
kwren's Avatar
That reminded me of a neighbor that we used to have that serviced cars out of his garage.
He would do an oil "change" by filtering the customers used oil through pantey hose and put the oil back in their cars and charge them for new oil!
liamrh, that wouldn't by any chance be you would it??
Sorry, I missed your point. Purolator is a pretty good filter.
The normal list price is $20 and change.
Old 12-13-2008, 02:48 AM
liamrh's Avatar
Yeah, $20 and change would definitely mandate the panty hose method oil change.
Old 12-13-2008, 04:20 AM
kwren's Avatar
Sounds more like some of Obama's change stuff.
Old 12-13-2008, 09:19 AM
wawazat??'s Avatar
Originally Posted by kwren View Post
Purolator L30251...
I *believe* that the micro rating should be micron rating and if so 32 is much worse than 19 as this refers to particle size that is captured by the filter.
Down to none
Old 12-13-2008, 09:30 AM
ZMan's Avatar
ZMan ZMan is offline
kwren - I think the smaller the micro rating the better.
See attached.
Old 12-13-2008, 02:32 PM
kwren's Avatar
See attached.
Very interesting Fun to learn! Got me thinking...
Now I am wondering what size particles are actually important to filter out?
Also filtering out smaller ones might stop or restrict the flow through the filter much quicker, giving it actually a much shorter life of filter efficiency, especially when we believe the "extended" ump-teen-thousand mile oil claims?
Interesting world, eh?
Keith
Old 12-14-2008, 12:00 AM
Smaller partical size, but much more filter material so it shouldn't clog very fast. I still change the filter at 3,000 miles or so.
