stumbling idle and backfiring, PLEASE HELP!!!!!
Ok, so the fwd legacy transmission is in the car and functioning properly without the legacy TCU or the fwd fuse in. With that out of the way I now need to focus on the more severe problem I have on my hands. The car has had an ongoing problem that I have yet to figure out. The car will randomly develop a stumbling idle and misfire quite badly. I have changed the coil packs and plugs recently and this problem still persists. When i was test driving the car it started stumbling at idle, misfiring under acceleration, and backfiring. I really need this problem resolved so any useful input would be greatly appreciated.
I has teh FWD LS-L |
Re: stumbling idle and backfiring, PLEASE HELP!!!!!
I am no expert so i may get bashed for this . I had a similar problem and it was a bad injector. suspected bad gas but it was enough to clog the injector. Subi dealer replaced one injector and it was fine after that . U have tried electrical assuming you have a good coil pack so my GUESS is gas .
I started the car this morning and put my fingers over the MAF and the car didn't even try to adjust the idle, it just shut off.
Ok, so I assume I need a new MAF????
if you cut off all air then it would kill it. I had a problem for a while where my intake clamp came loose and the tube slipped off soon as it did the engine would die. it was getting unmetered air.
