door handle removal
ok so i need to change my doors out because of a car accident, how do i remove the exterior handles and locks so i don't have to get 2 separate keys?
1991 xt6 eg33? 1993 gc track car |
KEY LOCK REMOVAL
1. Remove the trim panels (2 screws near mirror, two screws in armrest pocket, and 1 screw under the door handle-you have to remove the plate under the handle to see the screw) 2. Make sure you window is up and turn the rod holder to dissconnect joint, and then loosen spring securing key lock 3. Remove key lock from outer handle OUTER HANDLE 1. remove trim panel 2. Completely close door window lower galss. then detach outer handle and key lock from door latch rod. 3. Remove blind cap covering hole and loosen nut securing outer handle, and then remove bracket from inside. 4. Renove handle from outside This is straight from the service manual
