#76
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
#77
Don't stop working on it. Just change your plans. Instead of a leaf blower, what about a different source of electircally blown air? Something with say high cfm at low speed, and that which increases as the rpm's go up?
I'm reminded of those little electric race tracks i had as a kid. And strangely, I remember looking at the little guns that you used to increase it's speed, pull the trigger and it would go faster. I wondered how that worked, and noticed i could see through the vents something attached to the trigger that moved across a metal piece. That's how it changed, i thought, the metal acted as a variable resister, the current had to travel across more metal, thus reducing hte current traveling through. I've thought of this before, using the same theory behind the blower. Unfortunantly, the blower needs to coorispond with engine rpm, not the throttle position, but it could still be done. There are many opertunities out there for this. Also, if one isn't enough, what about 2, or 3? If your honestly curious, don't let the fact that a leaf blower won't sustain you. That just means you need something a bit more beefcake. You'd need to find the cfm at WOT at 6500rpm. Then, find an air pump that can produce say 4-6psi at that cfm rating. Then, built a sort of variable resistor that will take advantage of engine rpm, simple as adding a pulley to the serpentine belt or removing the AC and using that. Then get your base cfm at idle. Find a way to scale it from say 1psi at idle to a steady 6psi or so at 6500rpm. It's been done. It's not reinventing the wheel. If it was, we'd all drive ford model T's. Google is your friend. Industrial websites are your friend. They use blowers all the time, and big ones. I say keep at it. Go for it until you get bored, but don't get discouraged because one idea didn't work.
*No SVX at the moment...* 1987 Winnebago Elandan 35' 2001 Yamaha Roadstar 1600 2004 Ford Excursion Eddie Bauer, 6.0litre Power Stroke Diesel - Daily Driver. Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, scotch in one hand, body thoroughly used up, totally worn out and screaming HOOOOYA !!!!! |
#78
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
#79
in short.... stop trying to spend money on forcing air into your engine until everything on your car is in GOOD working order... All I see if your posts complaining about how bad your car runs and then these....
Tom |
#80
Maybe it will help you understand if I fill in the blanks for you
1320 watts divide by 14volts = 94.3 amps Quote:
because the alternator cannot supply enough current to run the car's electrical system and the leaf blower at the same time.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
#81
so i was looknig around the power equipment at the store today and i noticed the cordless saws that use 18v+ and have a bigger motor then my blower , its simple, ill just buy a battery for the saw ?? they sold 19.6v batterys for it though, but didnt say how many amps
#82
'92 SVX LS-L - 4.44 Tranny '67 VW Fastback - Undergoing restoration/ej257 conversion. |
#83
I was hoping that, in the interest of science, some would be conducted to come to this conclusion. I was also hoping that our OP would be willing to do that, in his pioneering efforts. Alas...
Disclaimer: The above post is on the internet. Last edited by LetItSnow; 01-13-2008 at 09:56 AM. |
#84
my 2 cents
plain and simple electric supercharger suck.I've looked into it 6 months ago, they don't provide enough boost to do anything.you probaly saw the same you tube video that i did were the guy claimed to get 14lbs of boost with a vacum motor or was it a leaf blower, ethier way it's a waste of time and money. source yourself a turbo out of the junkyard out of a capri or a probe,miata something that nobody normally thinks of, and look into www.ststurbo.com for a idea that will works.oh yeah thomas knight madé/makes the closes thing to a fesable e-supercharger and what i've read he sounds like a con-man. i seen STS on a show called "two guys garage" looks nice and no intercooler need
good luck |
#85
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
#86
i know alot of people having been waiting for this but, F MY LEAF BLOWER!!! IM GUNA DO THE STS AND PUT A TURBO IN THE BACK OF MY SVX, HELLA ROOM BACK wHERE THE MUFFLER GOES!!!! i mean, damn it seems so simple, sure the fuel system will be hard to upgrade but just look at how easy it would be not having to cram a turbo in my engine bay
#87
Hot stuff?
#88
what about putting in an STI turbo in it.
#89
yeah i really need to be boosted before june, thats when my high school drags come up and i really need to show some people up talking crap , sure its bracket racing but i atelast need better times then the kids who think they can beat me , anyways i just got a job so i should have money to do alot of this stuff cuzz i have no bills to pay except buy gas
#90
You're gonna blow your car up.
bLAh
