Old 05-21-2011, 12:26 AM
kjoyes kjoyes is offline
cold weather break problems
Hi this is my first post here on the network so bare with me and my spelling.
My problem is this i live in minnesota and i noticed when the weather drops below 0 or negive -10. I cold start my car it is like really hard to press in the break pedal. i have to use all my weight to get my car to stop. the best way to decribe this is it is like not having power steering but in the break pedal this is really dangerous because my car wants to go forward when i put it in drive.
But once my car warms up the problem goes away. also in cold weather my window tend to frost alot on the inside witch is annoying as well. feeback would be much apprehated like to get this done in the summer and not this winter.
Old 05-21-2011, 06:48 AM
Old Fogey
Re: cold weather break problems
First thing I would do is flush all old brake fluid out with new, as it's possible you have a bit of water in the lines, freezing at night. Start by sucking all old fluid from the master cylinder (I use an old turkey baster) and refilling with fresh fluid, then bleed each corner until nice fresh fluid shows up in bleed hose. I'm sure others will chime in with their suggestions.
As far as the inside windows freezing, is it possible you have some water on the floor, under carpets, etc? Also check the spare tire well under the trunk floor for water. Lots of folks have had problems with leakage finding it's way in via tail light gaskets or missing/misrouted sunroof drains.
Glenn
Old 05-21-2011, 12:42 PM
XT6Wagon XT6Wagon is offline
Might be the formulation of your brake pads thats making them useless at low temps. The EVO8 I had was kinda dangerous in 32degree temps as the tires and brakepads were more like blocks of wood than engineered friction devices. Which makes sense given a design goal for proper operation at high temps during agressive driving.
So if you don't know what kinds of pads are on it, might pay to start researching for some cold weather pads
Also you need to check your brake booster and its lines. Water/sealing issues can make for a hard pedal.
Old 05-22-2011, 12:01 AM
Earthworm's Avatar
Meow!
I've experienced this issue. The brake pedal doesn't move when pressed. It's not the pads. Bleeding the lines is your best bet.
Old 05-22-2011, 01:15 PM
flush in dot 4, it boils hotter than dot 3, dot 5 doesn't work with abs
Old 05-23-2011, 10:37 PM
bleeding the breaks with dot 4 sintentic would probable would do the trick, what is best and easyiest procedure to blead the break or to drain the master clinder, break boost would that be the culprit.
Old 05-24-2011, 02:00 AM
edmsvx's Avatar
edmsvx edmsvx is offline
Checkout this thread
http://www.subaru-svx.net/forum/showthread.php?t=56626
Should answer your questions.
1992 (JDM) CXD Ebony Pearl 90K km written off hail damage
1996 (CDN) Lsi, Polo Green, 296,000 km
2009 Legacy Spec B
Old 05-24-2011, 09:30 AM
Green1995SVX's Avatar
Cold weather break.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 05-24-2011, 10:15 AM
it's not the best way but the easiest way to bleed in new fluid is to gravity bleed it. turn a bottle of brake fluid up side down on top of your reservoir or just watch it and keep filling it up. crack open the bleeder at each wheel and let it drip out a small hose into a water bottle until it runs clear.
Old 05-24-2011, 10:23 AM
Old Fogey
I've never tried this, but possibly a good way to bleed them alone. What kind of time are we talking about, for say the RR corner?
Glenn
Old 05-24-2011, 10:39 AM
you probably want to let it drip for a good 5 minutes, less time in the front but the rears will drip really slow.
