replacing front axle
Fellers,
Front right hand cv boot is torn at the wheel. I can get a reman unit for about $90. Is this a hard DIY job, will I have to deal with the wheel bearing if I take out the old axle? Or is there an easier fix for the torn rubber CV boot? I've always heard it is cheaper and easier just to replace the whole axle. thanks for help Tdog |
I have the same problem. I have already got the axles, but when me and a buddy tried to attempt to fix them, we didnt' have the right tools. So, to add, Does anyone know the correct tools that are needed to install the front axles?
First off, use the seach button. This has been discussed several times already. Read those threads, see if they answer your questions, and then come back here and I will help you. I've replaced both my front axles, so I can help, but will not until you use the search feature.
- Rob |
I've used it about 3 times. I came up with some pretty good info, however, I couldn't find anywhere how big the axle nut is? I have seen 36, 34.
I think I will just have to take it to a shop and pay to have them replaced because I don't think I have the correct tools. |
>shrug<
Just take your wheel off. Pull the dust boot off and look at the nut. I believe its a 35.. maybe a 36. I don't remember. Anyway, get that socket, and the rest can be done with regular tools (except you need a hammer and a punch to get the pin outta the axle). - Rob |
Do you have to address the wheel bearig issue or is that not necessary? Has anyone use a speedy boot kit to fix a torn boot instead of the whole axle?
thanks Tdog |
i'll admit i am personally ignorant about doing this yourself, but i have discussed with the mechanic the possibility of just redoing the boot. he advised that as the amount of labor isn't significant and the cost of a rebuilt axel isn't that much why just do the boot when you can get a rebuilt axel for really very little more and eliminate a potential future problem made sense to me.
Axle nut
The axle nut is a 32mm or 1 1/4".
Axle nut
I should also add: use a 6-sided socket...Sears has it for about $5. When you reinstall, the axle nut should be torqued between 123-152 ft-lbs, the end of the axle should be about 7/16" from the hub lip and the nut (preferably new) should be staked. Good luck.
wolf33h PS. I have just replaced my rr wheel bearing, so have those numbers still fresh in mind! |
BTW, if your new axles don't come with new nuts, just swap the nut from one side to another, that way you can ping down a different side of it.
And yeah, it is 32mm. I remember now. - Rob PS: The biggest pain is that you have to put the seals from the old axle onto the new ones. They're not really seals, but more like metal little dust covers, that protect the bearings. And NO, you do not remove the wheelbearing,t he wheel bearing stays in the hub. You have to disconnect the hub from the lower control arm by disconnecting the ball joint, then you can swing the hub upward. |
The shop removes the axles, removes the old boots, washes the old grease and debris out, repacks new grease, installs new boots, and reinstalls axles. They say it takes only about an hour to do the both front axles. Total Charge is usually around $70, $40 for labor and $30 for new grease, boots and clamps. PS: I've never had the rears replaced. They seem to be holding up fine. Doug
Hrm. I disagree with your disagreement. You spent $70 dollars, and have done so more than once to get your boots replaced.
I spend 150 on each axle, that had an 80 dollar core charge. I took them back my old axles, and ended up paying $70 for each axle, clean, new grease, new boots, new everything, WITH A LIFETIME WARRANTY. - Rob |
Just my personal preference. Doug
