Check engine light
mine has just started to come on when engine temperature gets to "normal" halfway position, all fluids seem to be at correct levels?.
Any ideas from folks?. Car has just done 159,000kms and is 1995 OBD1
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Re: Check engine light
Check for codes.
ok will try youtube to find out how...
There are instructions on the site:
http://www.subaru-svx.net/forum/forumdisplay.php?f=94 a thread with pictures: http://www.subaru-svx.net/forum/showthread.php?t=63841
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
Odd that the light comes on when you hit operating temperature, and, presumably, goes off after it cools down again. Traditionally, when the "Check Engine" light comes on, it stays on until the problem is rectified, or, if it was a transient problem, stays on until several re-starts have occurred without replication of what threw the first code..
Also, I'd be suspicious of the factory gauge. It's far from accurate, and factory designed to lie to you. It may be that you're running into a slight over heating issue.. |
