Did SVX's ever come with OEM DRL's
Hi there,
just wanted to know if any SVX's ever came with Daylight Running Lights ? If so what countries go them (also where were they fitted, locations front and rear). Also what was the switch looking like (if they had one) to turn on/off the lights. TIA
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Re: Did SVX's ever come with OEM DRL's
All Canadian SVX have DRL. They use the fog lights. They turn on automatically when the car is put in gear. They turn off when the headlights are turned on but there is a switch to turn them on manually when the low beams are on. The switch is to the left of the steering wheel along with the cruise switch and rear defroster/defogger switch. When the high beams are on the fog lights turn off.
There are no rear DRL. Last edited by Blacky; 10-31-2016 at 04:48 AM. |
OK thanks for the info.
