Old 09-20-2010, 07:14 PM
elemgee elemgee is offline
Engine Code 24
While driving to work today my check engine light came on, and when I checked the code (its a 92 SVX) it was a 24, which I understand is the bypass air control solenoid valve. Can someone tell me where this is and is it something I can replace/fix? is this the same thing as the idle air control valve on the bottom of the throttle body? If so, I removed and cleaned it a couple of months ago, but didnt get the error code until today.
Thanks.
Old 09-20-2010, 07:31 PM
Re: Engine Code 24
Thanks.
Yes they are the same part.
Old 09-23-2010, 03:55 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Re: Engine Code 24
As in so many cases, you need to think of how the ECU can report the issue. Is a '92 model ECU sophisticated enough to expect an RPM increase and issue a code when it doesn't occur? More than likely not, so the next point would be that the ECU is observing a circuitry problem, in other words it expects to 'see' a specific voltage range and it isn't. My point is, before throwing a new part on be sure to investigate the surrounding wiring, connector, etc. - it might save you a few bucks. And, in the advent that it is that sophisticated, investigate the connecting hoses, etc. for holes, collapsing, internally pluggged, etc.
Old 04-10-2011, 01:01 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Re: Engine Code 24
This just happened to me today...got the code now and cleaned the valve a week ago. The resistance was fine when I removed the valve.
1995 Subaru Svx L / AWD
