Go Back   The Subaru SVX World Network > Regional SVX Forum & Clubs > US Regional Forums > Northwest Region
Old 01-21-2006, 05:45 PM
intelisevil's Avatar
<<<Alcyone
WANTED - Good repair shop - Portland, OR area
Please Help Me - I need to find a good reliable repair shop in the Portland, Oregon area.
The Power light flashes 16 times on my '92 Ebony. I pulled the stored and active codes - 11 (Solenoid A and/or possibly the resistor behind the battery) & 24 (Solenoid C).
I bit the bullet and took it to my nearest Subaru service department who claims they have six SVXi that are 'regularly' serviced there. I made an appointment with them and dropped off my car. I told them about the error codes and told them the AWD was binding in turns.
They hooked it up to their computer, (after they had it for a day and a half - I guess it's a good thing I made an appointment!). They said everything was working correctly, their computer didn't find any stored or active codes. I asked them if they had noticed the flashing Power light and pulled the codes from the TCU. They said they don't bother with that, their computer is much more sophisticated and it finds all stored codes and more. Since their computer couldn't find a problem, they decided it must be the transfer clutch pack.
Two hours later they told me parts and labor was going to be $1800, they started telling me the parts they would have to replace including the rear housing case (???). They then suggested that I not waste my money on this work and instead I should just have them replace the entire transmission for only $3800.
I politely asked them what I owed them at this point and told them I would continue driving my car as it is for now.
I am out $90.20 ($82 + 10% for misc. shop supplies) for them to ignore what my car and I tried to tell them was wrong.
PS: This is a reposting in the NorthWest Region per someone's suggestion.
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 01-22-2006, 10:58 PM
pipedream's Avatar
pipedream pipedream is offline
Send a message via AIM to pipedream
I would really love to have a shop reccomendation to take my car to here as well. Mine is having some severe electrical issues after being abused by theives.
Old 01-23-2006, 12:29 PM
They are obviously only checked the ECU codes (of which you have none).
Code 11 normally indicates a failing tranny resistor (hiding behind the battery).
Old 01-23-2006, 07:26 PM
<<<Alcyone
Yes, it appears to me that they never even looked at the car and just decided to try to sell me a new tranny . . .
Saturday, I pulled out the transmission resistor and checked it with my ohm meter - 0 ohms. I bought a 10 ohm, 10 watt resistor from Radio Shack and pushed the bare wires straight into the wiring harness connection. The shifting is much softer and the AWD binding in turns is much reduced. I'll try to find a 15 or 20 ohm resistor this week. I haven't had a chance to recheck the codes yet to see if code 11 has gone away.
Meanwhile - Still looking!
Dan
Old 01-23-2006, 09:54 PM
pipedream's Avatar
same here.
ill keep ya posted if i find anything.
i took my SVX to esquire import motors (in SW), and they were very good at fixing my car when it had misfires, as well as replacing my power steering pump system. they seemed to understand the car.
the only thing is they charged an ARM AND A LEG. i mean, it was rediculously expensive. It was like I had my transmissions replaced money wise when they were through. im only kind of exaggerating too.
Old 01-26-2006, 10:20 AM
STORMINORMAN STORMINORMAN is offline
In how many places are you going to post this ?
????? See my response in Tech Help, please.
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 88 420SEL I. @ 178K (what a buy!)
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
2001 Valkyrie Interstate @ 6.6K (Brynhild)
Y2K NightHawk 250 @ 1,500 miles
' 88 420SEL II. @ 208K
'85 F150 @ 135K
