SVX Climate Control Digital Temperature Fault
Hi all
My UK RHD SVX has developed the classic problem with the climate control unit, where it keeps counting down & resetting to the default temperature (18 deg C in this case), 'saving' & then batch processing requests for outside T, and generally making lots of irritating beeps while in this mood I am sure I saw a fantastically detailed write up with pictures, of how to extract the control unit from the dash, and fix the problem (capacitor leaking onto a PCB) but I can't find it ! Please could a kind person send me the link ? Many thanks Chris |
Re: SVX Climate Control Digital Temperature Fault
That's great - thanks !
good to see that people still find it useful - I have now fixed about 30 units...only one has come back with a different fault.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Hi ; it really is fantasically useful ! I really appreciate this service to the RHD community.
I stripped down my air con unit only to find someone had been there before me & fitted a larger capacitor ! I put a new one in for good measure, using my pathetic amateur soldering skills, but there was quite a bit of board damage from previous leaks, and on refitting I was getting the fault again, intermittently I bit the bullet and bought a second unit S/H from Japan - I took it apart this evening and the board / (original) capacitor both look absolutely fine. I will put it in this weekend - hoping for the best ! All the best & thanks again Chris |
