Old 04-23-2018, 07:16 AM
Tmazzola12 Tmazzola12 is offline
Re: More aggressive cam
Throttle bodies 👹
Old 04-23-2018, 09:09 AM
shotgunslade's Avatar
I’m sure EFI Logics would be willing to build you a 350 whp N/A engine. Just send them an EG33 long block and $25k and they’ll send you that engine in about 9 months.
Old 04-23-2018, 08:23 PM
I wish..I'm trying to save the rubber weatherstrip that was holding the end of the quarter together lol my car is no where near hp ready there's like 3 thousand clips and screws I gotta replace first
That first 100 hp seems to be the toughest in terms of which direction the build will go.. turbos are great, just not stock looking glad to know people have some interest in this
