Old 10-07-2008, 01:15 PM
cutrell3 cutrell3 is offline
HELP! KONI Question.
Getting ready to install. Are the rears adjustable? If so, how? Also if anyone has some more simple directions than what Koni sends please forward to Me.
Thanks.
Old 10-07-2008, 01:54 PM
sicksubie's Avatar
Re: HELP! KONI Question.
The rears have to be adjusted before they go in the car. You compress the strut all the way and twist it... Counterclockwise I think?? The koni instructions will tell you which way. Also on the rears put a washer at the top to space the top hat off the strut mount a tad so that the zip ties you use to hold the top hat down do not get cut by the mount.....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 10-07-2008, 02:05 PM
Old Fogey
Thanks.
My post from an earlier thread:
If you're familiar with general strut type suspension work, removing the assembly from the car, using a spring compressor and handtools to dismantle the assembly, that is the starting point for the Koni install. Here's a step by step job description for an Impreza, basically the same job.
http://www.scoobymods.com/forums/sh...ight=suspension
some pics: http://www.scoobymods.com/forums/showthread.php?t=36 including a pass-through ratchet used to hold the strut shaft stationary while removing the top nut (easily spun off with an air wrench).
I found the hardest part to be deciphering the small illustrations with international symbology, since the inserts didn't come with written instructions. One begins with the original strut and new insert, measuring the distance from top of the strut body to the nubs on the Koni and marking the OEM body the amount matching that measurement on the "instruction" sheet. Unlike carpentry, measure 4 times, then again, cut once! The intent is to leave the body long enough that when the Koni is inserted and bolted down into it the nubs are pulled well inside, immobilizing the insert. I marked around the body numerous times, placed it in a vice and cut with a hacksaw, working around the body so as to cut evenly and not break through until well started all the way around. Once completely cut lift the old shaft/innards out, dump any oil still inside, debur the cut and clean out the now empty OEM body. The Koni's come with a rubber sleeve that fits around, and inside the cut edge tightly but allowing the insert to pass through. Appears to be a water seal.
Now carefully mark the center of the round bottom of the body and drill the specified size hole DEAD CENTER, again cleaning up all shavings, etc. You're now ready to insert the Koni. The supplied allen head bolt fits up through the drilled hole and should just contact and start into the threaded receptacle in the Koni, IF you measured and drilled accurately. As the bolt is tightened it pulls the insert down into the body until the nubs disappear and the insert bottoms out in the body. Reassemble the new strut into the spring, bumpstop, cone washer and tophat . Repeat 3 more times and they're ready to go back in the car!
Glenn
