Transmission Questions... Need Help
I was reading the "Tranny Issues... Please Help" thread and I am having a very similar problem with the transmission and I was wondering if I could get some expert advice from you guys.
I have a '92 SVX and it has always worked good for me. A couple of months ago it started having a shifting problem. It doesn't slip it just doesn't seem to change at the right time as far as second gear is concerned. Sometimes it will get to over 4rpms before it will change to second and sometimes it will change out of second back into first when you slow down. It seems to do this mostly when accelerating downhill when it doesn't need much power. I also must mention that it never has a sifting problem when traveling uphill. It also works perfectly in all gears if you hit the manual switch and manually change the gears. I need to mention again that the tranny does not slip, it only changes in and out of second gear at inappropriate times so I'm hoping that it is something simple. Now let me decribe the original problem which may have led up to this. Me and my dad have installed an additional transmission filter and a cooler and have taken good care of it. A few months ago the main seal popped off the front of the transmission and fluid would pour out when it was cranked. We had the transmission taken out and the seal replaced and it has had this shifting problem since then. On the other thread I read earlier, you guys mentioned a brake band adjustment and the range selector mechanism. My question is, would any of these adjustments affect, help, or solve the problem I am having? How would I go about checking these out and is there any type of online guide as to their adjustment? Thanks for any help, Johnathon |
The fact that the fault appears to be possibly related to throttle position warrants checking the TPS (Throttle Position Sensor) as a first option. Speed and engine RPM sensors could be involved. You should run a diagnostic check. The how too section will provide information in both respects. You refer to the manual switch. The title is confusing. Are you aware as to exactly how this works and prevents starting in second for slippery driving conditions? First things first. Let us know how you get on. As you say, nothing indicates great expense.
Thanks for the reply.
The mechanic who worked on the tranny took it out replaced the seal and reinstalled it for less than $200 as a friend so I cant really complain much to him. He moved to a different state a few days later too... Since my first post I watched how it behaved more closely and I can say specifically the range of 2nd gear is so small that normally it will only be in second gear from 20-23mph untill 25mph. It will change out of 2nd to 3rd almost immediately after it changes to 2nd. I've did some playing around with the manual switch and I'm not sure of its exact purpose but I know if press the switch in and change the gear selector from 1,2,3,D it will change gears fine and stay in second ever how long I leave it there. I ran a diagnostic check as you suggested. It doesn't turn up any existing error codes. When I did a check on PREVIOUS problems it gave me one code: 32 (vehicle speed sensor 1) How should I proceed from here? Thanks for the help. Its nice to find a place devoted to the SVX!! |
Are you saying that ONLY when you have the Manual button switched in/on the gears can be selected properly with the selector lever, including first (1)? Please confirm or explain in detail.
At this stage it would appear that all is OK when not under electronic control and accepting this as fact the following comment applies:- I do not have data on the US model and there are two speed sensors, one of which is the primary sensor and I would suspect this to be numbered as No. 1. From what you report, you could very well have an intermittent speed sensor which is not registering a constant fault signal. On this basis I would replace speed sensor No. 1 as a first option.
Yes only when I have the maunual switch on can the gears be selected without problems.
I did a good bit of research yesterday and read the the how-to document on brake band adjustment. It has a chart on improper brake band clearance and their symptoms. I was amazed when it decribed my symptoms exactly at the top of the chart as it reads: Clearance 1. Too Wide: Upshift from 1st directly to 3rd gear occurs. 2. Wide: Engine RPM increases abruptly while shifting from 1st to 2nd or 3rd to 4th. Time lag of at least one second during lockdown operation from 3rd to 2nd. If this is indeed my problem and the clearance is too wide, which way do I turn the adjusting screw to narrow the clearance? Also, when I found the brake band adjusting screw on the transmission I was amazed that I could turn the bolt freely with my hand! We tightened the bolt back in place being sure not to turn the adjusting screw. Would the bolt not being tightened on the adjusting screw have caused it to loosen or what damage could that have caused? |
Good one.
As you now identify the symptoms exactly and have found an existing fault you are well on track. You have not reported any slippage it is unlikely that any damage has occurred. With the adjuster not properly locked, it would most certainly have tended to loosen and upset the adjustment. I think you have referred to the lock nut as a bolt. Complete information regarding adjustment is in the How Too section under transmission.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 12-27-2007 at 09:59 PM. Reason: Typo |
