Closed Thread
Old 11-13-2007, 09:51 PM
jeffast jeffast is offline
I kill more trannies then god
ignition switch
i need a new ignition switch, mine doesn't always start the car, how hard is it to replace the switch
1991 xt6 eg33?
1993 gc track car
Old 11-14-2007, 12:30 AM
kwren's Avatar
kwren kwren is offline
Maybe not
the car may not start even with a new switch
Old 11-14-2007, 01:46 AM
when i turn the key all the lights go out like there suppose to and the starter cranks weakly, but evrey third time or so the lights go out and the starter doesn't go. if i jumper the solinoid on the starter to the battery it starts instantly(and the starter sounds stronger, but i could be hearing things), evrey time, this would be a problem with the ignition. As it is worn out on my car i would just as soon replace the switch and maybe the lock cylinder while i'm in there. As far as i know the svx doesn't have a starter relay. so the ignition switch is bad.
so got any idea how hard it is to remove/install or what...
thanks for the useful comment
1991 xt6 eg33?
1993 gc track car
Old 11-14-2007, 05:45 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
It's not hard to replace...do a search on "ignition switch"....there are pics also in one of the threads. There are security screws on this device that only allow you to tighten so far, then I think they break..I'll have to check.
1995 Subaru Svx L / AWD
Old 11-14-2007, 05:47 AM
msvx95's Avatar
It's just a phase
Yes in fact look at the thread called "ignition switch pics"....Kuoh has a great write-up on this..... good luck.
Old 11-14-2007, 05:57 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
<link to that thread>
Old 11-15-2007, 10:55 AM
kwren's Avatar
You gave yourself a clue!!!
Of coures it isn't the battery. you said "if i jumper the solinoid on the starter to the battery it starts instantly(and the starter sounds stronger", ... My starter sounds stronger all the time with the Bosch relay on it because it is getting the full voltage from the Battery right to the starter!
That certainly doesn't sound batteryish to me LOL
If it is, I would like to have a "bad battery" like yours, maybe at least to start my SVX on a cold morning
Old 11-15-2007, 12:12 PM
lol, i changed batteries at the same time i finished the wiring for my 5spd swap so i could start my car from the inside9i was starting it under the hood with a wire to the solinoid. i charged my battery overnight and it now starts the car without a problem. but it seems to lose significant power if undriven for more then 12 hrs...
thats why i'm thinking that my battery is bad,
1991 xt6 eg33?
1993 gc track car
Old 11-15-2007, 01:10 PM
kwren's Avatar
things that are not constant...
are sure a bummer. I would suggest if you are intent on a new battery, Costco batteries are great and virtually guaranteed forever ( if you play your cards right)
Might swing by the neighborhood auto parts store and pick up a Bosch relay for stock in case you need one anytime soon! LOL
Take care and hope it all works out soon.
Keith
Closed Thread
