Remote entry?
Hi all, newbie.
92 teal green lsl 137000km (82000ish miles) 5 speed Just a few quick questions to start with. 1. My door/ignition key does not fit the trunk, is that normal? 2. Remote entry, i received just a key, how would i know if the car is equipped with remote entry? 3. Small cosmetics such as seat levers, is there a good source? Many thanks Glad to join the elite :-) Clive Last edited by canbritsvx; 05-12-2009 at 11:29 AM. |
Re: Remote entry?
Hey if your car has a ' security ' button just to the left of the steering column, then it has a factory alarm system - if you like, I bought a fob for the 92-95 svx that I can't use as I never checked for this - if you want it, pm me and i'll send it to ya.
my door/ignition key also does not work in the trunk, perhaps the key that you and i have are valet keys? I have to open my trunk using a lever on the floor |
Re: Remote entry?
Did Canadian SVXs get the keyless entry/security system?
Even if you have the Security button on the dash, it's still possible that the module was removed or has died (which is all too common). Does your key work in the glovebox? If it's a Valet, that should not work either. Exterior locks (trunk or door) can fail due to dirt/corrosion too). Is your key the SVX OEM key? If so it should have either X or Y below the key number. X is driver's, Y is valet.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
Re: Remote entry?
Hello to a fellow Ottawan.
There's 2 SVX at a junk yard on Vanier Road in Aylmer 819-682-3525. Last edited by Blacky; 05-13-2009 at 03:48 PM. |
Re: Remote entry?
Thanks for the help guys i will ceck the key, no i do not have the security button, does that mean i dont have remote entry?
Re: Remote entry?
That would be correct then. Most Canadian SVXi did not come with the security system.
Re: Remote entry?
Mine didn't, I had an aftermarket alarm/keyless entry/remote starter/stereo installed immediately (the factory CD didn't work and the 15 year old speakers were not acceptable by modern standards).
Good to know, I always wondered why one key worked and the other didn't. I made 2 copies off the Y key and got all pissed off at the keymaker because they didn't work in the trunk or glovebox. he didn't know about the X and Y either. |
