Old 10-13-2011, 08:30 PM
Rod.'s Avatar
Rod. Rod. is offline
Re: What this sun visor problem?
I've read that Visagra helps...
Rod.
'97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD
'92 Ebony LS-L #6851, USDM (sold)
'08 Forester (wife's)
'06 STi (traded for the Forester)
'94 Legacy wagon (sold)
Old 10-13-2011, 08:50 PM
I found out many years ago that pulling down the drivers sun visor with your right hand gripping the outer edge of the visor stresses the pivot joint greatly. The same with pulling the passenger side down with your left hand. Seems perfectly natural, but you tend to bend the joint and shear the connection.
I always twist my visor down by grabbing it at the pivot point with my left hand.
Your passenger can just hold the pivot point of their visor steady with their right hand and pulling with their left. You can also use the two-handed method on the driver's side if you prefer.
Still have the same perfect visors since new in 1996.
Old 10-14-2011, 01:26 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
John, your definitely the exception then the rule
1995 POLO LSI 76K MILES SOLD
Old 10-14-2011, 10:44 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
To keep mine from getting worse, I use one of these. One wire slips between the headliner and vinyl trim, the base rests against the trim and the other wire holds the sunvisor in place. Can hardly see it.
Gene
Gene and Ben
Old 10-16-2011, 10:37 PM
alia176 alia176 is offline
Send a message via Yahoo to alia176
I found a tiny magnet on the side of the toolbox and using it to keep the flap from falling down into my field of vision.
Now, off to fix the droopy passenger side visor.......
If it ain't broken it, doesn't have enough features!!!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 10-17-2011, 07:18 PM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
do not use Velcro...it will take the top piece off as well...trust me it doesn't look good
i couldn't use magnets either...none of the magnets i tried could hold it up there!
but you can fix it using the tutorials in the "how to do docs" ...there are 2 tutorials there and both work perfectly...
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
Old 10-18-2011, 06:39 PM
kwren's Avatar
kwren kwren is offline
Maybe... but same rules here! Have to treat them with kid gloves!
Keith
Old 10-18-2011, 06:41 PM
kwren's Avatar
How to do... Subaruparts.com
Keith
Old 10-18-2011, 10:06 PM
The NEWBIE
Keith
I don't understand what you mean... I meant the how to docs in this forum!
David !!!!
DIY FTW!
Old 10-19-2011, 07:10 AM
Gene
My drivers side visor droops.
The previous owner had this thing in it. It keeps it from falling.
Old 10-19-2011, 04:37 PM
bwb3's Avatar
Those were offered on Ebay at one time. Had a pair, pricy but they worked. Unfortunately broke when uninitiated riders pulled the visor down without sliding them out of the way (including my son).
Gene
Gene and Ben
Old 10-19-2011, 05:35 PM
kwren's Avatar
David !!!!
Just replace it with a new one! The SVX is a "class act"
Keith
Old 10-19-2011, 11:38 PM
The NEWBIE
Keith
I could not have guessed that!
Subaruparts.com wants ~$130 for it! or i'm mistaken in some sort!
looked up for ones from other subis but most have 3 screws now...
I still rather do the how to doc way. much cheaper you know
DIY FTW!
Old 10-20-2011, 04:17 AM
andreoz andreoz is offline
Send a message via Skype™ to andreoz
I had found this problem when the sun visor seemed to fill out with some gas/air when heated up over the years and it was round almost like a baloon - making a pinhole in it solved the problem!
Old 11-03-2011, 09:52 PM
dbarnblatt's Avatar
I can't recall right now but don't the SVX visors have the support point like the BMW example?
Many sun visor designs have a bracket that holds the unsupported side. You can flip them up or down easily or unhook the visor to swing it to the side, when necessary.
Quick photo of a BMW 775 visor. Search Google and almost all of them have 2 support points. There are even visors with monitors and DVD Players built in
The SVX design is flawed and makes no sense. The stress you apply at the free end is sent back to the lone pivot point.
