*reowreowreowreow* ...She's dead, JIm.
Tried heading out to work this morning, but the X would not start.
Same problem as usual, I turn the key and get nothing, so I tap it back and forth and it usually kicks in. Not today. It just kinda faded away. It's getting colder and the car sat all weekend so I figured the battery was just drained and the oil kinda thick. I hooked up my portable jumpstarter/trickle charger and tried again. It just kept crankin' like a bull. I hitched a ride to work and I'm thinking about all day, I wonder if my fuel pump is shot? Power is good. Starter might be worn (dunno how it works). I believe it would still start if I lost a coil. The sound it made just had me thinking "fuel". Thing is, a couple days ago I swear I smelled gas as I was driving along. You never know it could be some junker in front of you, and also ironically, I had just bought some oil and gas and oil smell the same to me. It could have been the oil, though the containers were sealed as far as I know. I was also eating ... who knows. --- Here's what I need right now. I need to diagnose the problem. The car cranks forever, so we can rule that out to spark and fuel, right? I know there's some trick with a screwdriver to checking spark but I forget what to do, and I need to know the best place to disconnect a fuel line and see if there is pressure.
Ok I think this is important. I just went out and listened to it again and it's not making the normal "REE OW" sound. It's just kinda going "REE REE REE" like there is no resistance.
Sounds like a starter issue but I know NOTHING about starters. I could create a sound clip, if anyone thinks it would help.
Free running starter with no resistance could be timing belt. That's how my old GL10 went.
Gene
T belt is tight and looking good.
Battery is on the trickle. Someone here is dead-set the battery is the culprit, but I'm not so sure.
K I'll get on that.
Turn the key foward to the on position but don't start it... Listen for the fuel pump to turn on and a few seconds later it should turn off. Start there and get back to us
Tom |
It's also raining outside. ):
Teh linkage
#4 in this diagram. pretty darn pricey for a new one but a used one works. A new one will def. work better but it will cost you Tom |
